Go to Post I'm thinking they subscribe to the thought that "the best offense is a good defense". They are from New England, after all. - Travis Hoffman [more]
Unread 11-01-2012, 20:18
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Jaguars and rc?
Ok, so we tried to run a victor of an rc receiver but this one required a signal mixer we didnt have. So we are wondering if a jaguars can be run off an rc signal. If so do you think the one we tried to use with the victors that failed will work for the jaguars?
Every day is a new adventure!!!
Unread 11-01-2012, 22:53
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: Jaguars and rc?
We use rc systems to test our drive trains with Jaguars all the time. No special cables needed.
Unread 12-01-2012, 06:16
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: Jaguars and rc?
Does that one work with the victors? Apparently some rc are different.
Unread 12-01-2012, 06:48
BAM BAM is offline
FRC #2425
BAM is an unknown quantity at this point
Re: Jaguars and rc?
Victors should work with a standard RC equipment. Its all running of of PWM signals. What color (if any) does the LED on the Victor show?
Unread 12-01-2012, 07:46
Re: Jaguars and rc?
Some RC equipment does not drive the PWM signal strong enough for the electronics in the Victor. IFI sells a signal booster powered off the PWM 5V line for use with this type of equipment.
Jaguars do not have this issue as far as I know. That means it is certainly possible to have an RC receiver that works with a Jag, but not a Victor
Unread 12-01-2012, 13:48
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: Jaguars and rc?
Ok thanks. I'll try it tonight and see. Fingers crossed.
Unread 12-01-2012, 17:51
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: Jaguars and rc?
Both Jaguar and Victor have similar front ends on the PWM interface; they both use opto-isolators. The difference is likely in the resistor value used and resulting current drawn from the PWM signal source.
If you use a Jaguar for this application, you'll need to recalibrate it since the range of the PWM signal is wider on the Jaguar than a normal RC PWM signal, and if left uncalibrated you will not get full output at the full RC PWM range (1.0 .. 2.0 ms). The Jaguar range is optimized to work with the cRIO.
And if you move it from your project back to a cRIO run robot, don't forget to re-re-calibrate it
Unread 12-01-2012, 18:22
AKA: Scott McMahon
Re: Jaguars and rc?
Someone with better insight than I w.r.t. the Victor's front end pointed out that the opto-isolators used on the Jag and Victor are not the same and this is the main difference.
I still stand by the advice on re- and re-re- calibrating.
