Go to Post If that many teams could do it successfully every match this year I will eat my robot. - Jay O'Donnell [more]
Unread 12-01-2012, 09:47
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Using a Plunger System to Launch Balls
If I understand you correctly you're using a piston to directly launch the ball? If you want to go this route I would strongly suggest using either multiple small-diameter cylinders with one solenoid valve per piston, or multiple solenoid valves per piston if they are larger. These are the only way to get enough air flow for an effective pneumatic shooter that I know of
