Go to Post I was considering letting Big Mike bearhug me for the warmth. - Barry Bonzack [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 12-01-2012, 11:02
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
Re: Using an encoder with a two CIM gearbox
is it posable to attatch one encoder to two Jags with diodes so it wont get feedback to the other one?
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 24-01-2012, 12:37
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Doc543
If you use diodes the forward voltage drop will reduce the output voltage from the encoder (0.3VDC - 0.7VDC) and if you look at the encoder under that load you'll discover that might not be desirable.
More importantly you won't really get noise isolation from that.
