Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 10-01-2012, 21:14
RedLeader342's Avatar
RedLeader342 RedLeader342 is offline
Fabrication/Drive Coach
AKA: Justin White
FRC #0342 (Burning Magnetos)
RedLeader342 is a jewel in the roughRedLeader342 is a jewel in the roughRedLeader342 is a jewel in the rough
Re: Team 3489's Catapult Prototype
Originally Posted by Tom I View Post
If you're throwing that reliably from 25 feet, maybe you could consider specializing in throwing from the other side of the court, say like in your protected alley. This would allow you access to balls automatically from your alliance inbound area, and maybe you'll just always throw from x- distance away. sure it would limit your range of throwing, but hey "The Jack of all Trades is the Master of None." Being amazingly consistent at one thing is better than being somewhat consistent at a lot of things.
unfortunately, this alley isnt protected. its purely decorational. its in the rules ;D
2009-Mechanical and Scouting student,342
2010~12-Mechanical, Fabrication, Operator,342
2012~13- Fabrication Mentor,3196
2013~Present- Fabrication/Drive Coach, 342
Unread 10-01-2012, 21:56
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
[G28]
Robots may not touch an opponent Robot in contact with its Key, Alley, or Bridge.
Violation: Foul; Technical-Foul for purposeful, consequential contact.
You're right about one thing..... it is in the rules
FRC Team 3489 "Category 5"
Unread 10-01-2012, 22:30
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Neat!
Are you venting the cylinder to atmosphere or which fittings are you using to make it double action. Last time we tried to make one like that we had issues getting it to work as a double acting cylinder due to the volume of air we were trying to move through a fitting.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 10-01-2012, 23:16
CrashTestPilot's Avatar
CrashTestPilot CrashTestPilot is offline
AKA: Rafal Myslak
FRC #2338 (Gear It Forward)
CrashTestPilot is an unknown quantity at this point
Is there a rule that does not allow for using phisical contact with field elements to allign for shot? Could you say mount this catapult in a way that when the robot is touching the field wall and the bridge in your own alley you are perfectly alligned to make a x point shot? If the feeder was on the back end you could pick up additional balls that are rolling down the alley without moving the bot. Maybe have an allience partner feed the balls to you once you plant the robot in that perfect spot.
You may be on the path to design a "sleeper" robot that will surprise some sceptics.
Unread 11-01-2012, 09:23
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Originally Posted by Phyrxes View Post
Neat!
We used standard 1/4" OD push-to-connect fittings.
But we sorta cheated on the valve, using one that has more flow than is allowed in the rules. Later when we installed a "legal" valve our range dropped about 15%. I think we can get that back if we go to two smaller cylinders, each controlled by it's own valve.
Larger cylinders = more power, but more time to fill & exhaust.
Unread 11-01-2012, 09:48
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Multiple small cylinders, each connected to its own legal valve is an excellent way to achieve higher speed. Another trick:
(Assuming you want high speed and force on cylinder extend, and retract speed / force are not as important.) Use multiple small cylinders, each connected to its own valve. On all but one cylinder, do not put a fitting in the retract port, and plug the retract port on the valve. On the final cylinder, connect as normal. That will greatly reduce the amount of air you have to force through the exhaust ports on the valves during the extend motion, and eliminate much of the back pressure on the cylinders. We used this technique in 2008.
Third trick using multiple cylinders:
To vary speeds: Connect all cylinders to the valves in the normal fashion. High force kick, extend all cylinders.
Lower force, extend some cylinders, keep some in retract. A cylinder has more force in extend than it does in retract, so as long as you have as many or more cylinders extending than retracting, it will extend. If you use four cylinders, that will give you three different extend speeds / forces. We did this in 2010 (we also used surgical tubing to help extend, so we could actually extend with all but on cylinder in retract)
Former Mentor Team 1771
Former mentor Team 4509
Unread 12-01-2012, 06:35
AKA: Kevin Thorp
While one group was working our a catapult prototype, another built a single wheel shooter:
http://youtu.be/LXIYwYKEA8Y
We knew this first iteration would not have a lot of range, but it'll be a good test bed for experimenting with aiming and speed control.
Unread 12-01-2012, 12:17
professorX professorX is offline
AKA: Xavier
FRC #1660 (The Harlem Knights)
professorX is an unknown quantity at this point
I would like to mention to not forget about the 60in tall limit if shooting from half court for the catapult design.
Unread 12-01-2012, 12:36
Mr. Pockets's Avatar
Mr. Pockets Mr. Pockets is offline
Optimist Alumnus
AKA: Nathan
FRC #1189 (Gearheads)
Mr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond repute
Thanks! But remember when you watch these types of videos the robot is usually perfectly still, at a fixed distance and angle to the goal, and no other robots are harassing it.
That's actually representative though. If you just fire from the top of the key everytime and score consistantly each time, then this model works fine.
If you're getting a solid 25' with each of your shots though I'm gonna echo the others and suggest that you consider working as a resupply bot. Saves the issue of manual reloading, and makes you one valuable little pony for your team
Year 1: Learned about Projects
Year 2: Learned about People
Year 3: Learned about Pride
Year 4: Learned about Promise
I came to robotics for the robot, but stayed for the people
2012/13 Melancholic retiree and wistful dreamer
Unread 12-01-2012, 12:39
mr.roboto2826's Avatar
mr.roboto2826 mr.roboto2826 is offline
AKA: Niklas Olsen
FRC #0148 (Robowranglers)
mr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nice
If you truly are interested in the catapult design you may want to take a look at this robot from 45 in 2006. http://www.chiefdelphi.com/media/photos/23258
Unread 12-01-2012, 13:38
AKA: Justin White
Originally Posted by HumblePie View Post
[G28]
oops. read wrong. saw that the lines between the key and fender were decorational and thought it was the alley. on page 5 of the arena rules
however it just says touches another robot, doesnt say you cant go into that zone ;D
Unread 12-01-2012, 13:50
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
You can use a lead screw with 80/20 linear slides to effectively shorten the arm when you want, thus lowering the ball speed at launch. You can also just sit at the slot and launch the balls 50 feet. However, IF YOU DO THIS, make sure your arm never extends up over 60 inches.
You may also be able to put 2 solenoid valves on the cylinder such that you can have 2 different working PSI's, giving you a high-pressure normal range and low pressure ultra-short range (for when you're right next to the thing). Double check the rules though; I know after 2008 they changed the pneumatic rules up a bit to prevent specific instances of multi-valve issues from occurring. You may also be able to hook a servo up to flow-control valves to limit the speed at which the cylinder fills if the multi-valve thing doesn't work.
The hardest part of this will be side-side accuracy, IMO.
2017 Scoring Model
CAD Library | GitHub
Unread 12-01-2012, 14:15
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I was just made aware of this rule by SIRI (CD user):
<R78> The outputs from multiple valves may not be plumbed together into the same input on a pneumatic cylinder.
Just FYI.
