Re: The holes in the bridge are for?
Well, that makes sense. And a maximum of 14 balls can be held on the Coopertition ramp, so the 15 fits there.
Where can I find these dimensions? I tried looking in the manual, but there are no specific dimensions. Any thoughts?
After looking through all of that material, I still could not locate the size of the holes and the proper spacing. I'm assuming that the holes are predrilled when given to fields, but how can we replicate this with our version (plywood)?
Game Specific Drawings - Sheet number GE 12095 - page 106 in the pdf file.
The holes are 1-1/8" diameter, and will wind up being 1/8" deep. At that depth, it's probably just to steady the balls at the beginning of the match.
- Steve |
#7
I didn't even think it would be for steadying the balls at the beginning of the match. The manual *I believe* is very vague as to the position of the placement of the balls, but this COULD be a possibility. Random placements at the beginning of the match (ala 2005 tetra placements at the start of a match) maybe?
Aside from that discussion, my first thought for the purpose behind the holes (which I'm surprised no one brought up yet) would be a deterrent to add a vacuum suction cup to the bottom of your robot to hold yourself in place. This was assumed by myself & some of my other veteran team members from experiencing first hand teams doing this in the past for games (2006 actually comes to mind - or any other year with a surface similar to the plastic(ish) top of this year's ramps. Do the "holes" actually go all the way go through the top most ramp material to let air/other things fall through, or are they just countersinks? Last edited by Elgin Clock : 13-01-2012 at 02:07. |
#8
The field drawings show them as thru holes in the top layer of polycarbonate.
#9
Well then... My first impression is the one I'm sticking with. A deterrent for attaching yourself to the ramp permanently at any time during the match with a suction cup of any kind.
#10
It seems very likely to me that the holes are for the balls. |
#11
The holes are for ball placement.
With 3 robots on the bridge, no robot can move in order to balance. Thus the only way to account for differences in weight & c.g. would be to have an arm or slide that can transfer a little bit of weight from one side to the other. It's also much more precise than driving. Don't think robots will have arms this year? I suspect many teams will have bridge lowering mechanisms powered by motors. "Quick! Everyone lean left!" ![]() |
#14
