Go to Post FIRST was the best thing that accidentally happened to me. - Stephen Kowski [more]
Unread 12-01-2012, 16:00
gaurav.agashe gaurav.agashe is offline
FRC #0886
gaurav.agashe is an unknown quantity at this point
Arcade Drive AND motor-drive
Hello,
How can I use the same two motors (at PWM1 and PWM2) with the Open-2motors and Arcade Drive vi's in Teleop, as well as with the Motor-Open and Motor-SetOutput vi's in autonomous?
I want to be able the command each motor independently in autonomous mode to increase distance/straight-line accuracy (aided by encoder feedback).
But in Teleop we have no need for the encoders, so I want to stick with the simple and easy-to-use ArcadeDrive vi.
Any suggestions?
Thanks!
Unread 12-01-2012, 16:31
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Re: Arcade Drive AND motor-drive
I'd just use the tank drive VI (can't remember the name -- been 2 years since I did FRC LabVIEW -- Tank Drive?) in autonomous. It functions exactly like 2 Motor-SetOutput VIs would.
Unread 13-01-2012, 07:43
Greg McKaskle Greg McKaskle is online now
While this is possible, using the Open Existing Motors version of Robot Drive, I don't really think it is necessary. I think you want to use the encoders difference to set the X of the Arcade. Scaled and possibly using other control terms.
Greg Mckaskle
