Battery
Hi, our team was wondering if the battery had to be in a up right postion on the robot or could it be at a side or an angle? We could not find anything in the manual.
Thanks for any help! ![]() |
Re: Battery
-Duke |
Ok thank you so much!!
Re: Battery
Out of curiostity do you know if we can have rope lights on our bots? like those xmas lights in a tube?
Re: Battery
With respect to rope lights, I'd say those fall under Non-Functional Decoration and suggest looking at those rules. |
Re: Battery
In reply to battery orientation there are two aspects to take into account for a correct answer here, battery specs and robot rules.
For the battery specs, because it is an AGM battery, you can place the batteries in any orientation and not have a diminished performance because of the orientation. As for the game and robot rules, there are no rules to restrict you from placing the battery in any orientation on you robot, but i will give you the following recommendations for best performance on the robot.
Also a couple good practices to prolong the life and performance of the batteries are:
Obviously these are not all inclusive lists but good practices with respect to the battery. Last edited by dez250 : 13-01-2012 at 13:48. |
#7
Re: Battery
You can, just make sure to abide by [R05] and [R08] (i.e. don't put them on a shiny disco ball).
#8
Re: Battery
For the same reason, don't install the battery upside down. Any other direction (upright, on its side, flat) is fine.
#9
Re: Battery
If one reads the manufacturer's sheet on this battery it would lead to believe that you can mount and use the battery in any orientation. I would suggest that upside down is a bad idea because you can't see the insulation that should cover the terminals and you can't see if the terminals are under stress. Please remember that the metal terminal that is sticking out of the red and black plastic on your battery is simply soldered to a round terminal inside the battery. Any stress can damage or break this connection. This is not a repairable fault. While the batteries we use are AGM and theoretically have the acid impregnated in a glass mat, I recommend that teams do not charge them upside down. This is just good practice to prevent some of the problems already listed.
#10
Re: Battery
-Thomas |
#11
Re: Battery
Re: Battery
Whoops, thank you for pointing out the typo, updated.
#13
Re: Battery
Everyone knows not to put the battery in upside down. All the electrons will fall out when you disconnect it. Or is that what that AndyMark plastic plug is for?
#14
Re: Battery
Actually its not far from the truth.. in 2010 our battery was installed with a downward slope (Terminals downward made the cable connection run much shorter) Well lo and behold after one match we noticed something that looked little damp in the battery carrier after removing the battery... Very carefully we checked with a little bit of baking soda and yup the battery had leaked. From that point on batteries are always right side up. Having a leaky battery is not something you want to deal with during competition.
#15
Re: Battery
I wouldn't stress a few extra inches of #6 wire to make for better mounting. 1000' of #6 wire has a resistance 0.3951 ohms. Even at a 50 amp draw, 6' of #6 gauge wire has less than 0.25 volts drop. I'm not saying be wasteful by any means, just that if you need an extra inch or two to make a better robot, it's worth taking it. Go here to play with values to see what your losses will be:
http://genuinedealz.com/voltage-drop.html -Mike |
