Go to Post it's possible, based on his widespread approval, that Frank is in fact a collection of kittens in a human suit - Andrew Schreiber [more]
Unread 08-01-2012, 15:58
Ian Kaplan Ian Kaplan is offline
FRC #1155 (SCiBORGS)
Ian Kaplan is an unknown quantity at this point
Java Camera Feed to Laptop
As our first goal for the season, we would like to get a camera feed to the driver's station.
Does anybody know the sample code necessary to accomplish this task?
Thanks.
Unread 08-01-2012, 19:51
Derek012's Avatar
Derek012 Derek012 is offline
I miss my frisbees
FRC #4564 (Orange Chaos)
Derek012 is on a distinguished road
Re: Java Camera Feed to Laptop
There are two methods I know work well. You can connect the Axis Camera via crossover cable to your cRio and from there you can use the AxisCamera class in the wpilibj to get the camera instance. Or you can take another approach and connect it to the DLink directly and get the camera data directly without going through the cRio. If you want to go into image processing going through the cRio would be a slower choice and may introduce lag if you demand to much of it. If you bring it to the classmate you have more processing speed to help you process your image and not "bog down" your Rio.
Unread 10-01-2012, 14:36
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Thanks.
I know that you can view the source code of the diffrent classes so you would probably have to look at the source code of the AxisCamera class and modify it to acommodate the method that Derek012 suggest where you bypass the crio.
Unread 10-01-2012, 14:42
Is it possible to use a usb breakout board and connect it to the sidecar?
Unread 12-01-2012, 16:57
GuitarPlayerTim GuitarPlayerTim is offline
Mechanical
AKA: Timm
FRC #3171 (Best of the East)
GuitarPlayerTim is an unknown quantity at this point
connect your computer to your ethernet bridge through a straight-through CAT5. connect the camera to the bridge with a crossover cable.
set your computer IP to 192.168.0.6
enter the camera through a web browser by typing 192.168.0.90 to make sure you can connect.
then use the Setup Axis Camera program.
keep IP as 192.168.0.90
make subnet 255.0.0.0
in your code:
inside public *INSERT CLASS NAME HERE*(){
AxisCamera camera = AxisCamera.getInstance();
once everything is saved, plug the camera into CRIO port 2.
change computer IP to 10.TE.AM.5
make sure your driverstation is updated, run the code in, and you should get feed.
a little gift from team 3171: Westhampton Beach Hurricanes
Unread 12-01-2012, 17:41
This procedure will not work as listed. The camera code in WPILibJ is defaulting to 10.xx.yy.11 for the camera. You can either use the Robot Radio option of the Camera tool and plug the camera into the robot radio or your first call to GetInstance should be:
AxisCamera camera = AxisCamera.getInstance("192.168.0.90");
