Go to Post Every game design should be a means to an end. - Mark McLeod [more]
Unread 11-01-2012, 13:34
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Reflective Tape Purpose
In the FIRST Choice there is an LED light ring you could use to reflect off the tape. http://www.andymark.com/Ring-light-f...-p/fc12-60.htm
Unread 11-01-2012, 14:19
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
Has anyone tested how far the retro-tape will be able to 'reflect' the ring light from? (IE: From the other end of the field?)
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 11-01-2012, 18:14
Rizner's Avatar
Rizner Rizner is offline
FRC #2425
Rizner has a spectacular aura aboutRizner has a spectacular aura about
Has anyone tested it with the Kinect? I'd imagine it works well with the Kinect IR emitter (there's an emitter on the Kinect, as well as an IR camera and an RGB camera), but haven't had the chance to check it myself.
Unread 11-01-2012, 18:49
Greg McKaskle Greg McKaskle is online now
I believe this is the type of lens I purchased a few years ago, wasn't too careful with my order, and wound up without an IR filter. The result was very washed out colors.
http://www.edmundoptics.com/products...productid=2196
The lens thread is I think called a 7mm lens mount. I believe the 206 lens has a 4mm focal length.
Greg McKaskle
Unread 11-01-2012, 22:36
gnunes gnunes is offline
FRC #1391 (Metal Moose)
gnunes has a spectacular aura aboutgnunes has a spectacular aura aboutgnunes has a spectacular aura about
Greg-
Thanks! I had already found that page, and was guessing that it was a match. Looks like the mount is 12 mm (M12 X 0.5).
On a related topic: I would like to start my programming team with image processing, but we don't have a robot, or a practice field, or etc., etc.. But it looks to me like you have a pile of images of your test field. Would you be willing to post them somewhere in this forum or some other suitable place so we can all download and start practicing our image processing chops?
Cheers,
-Geoff Nunes
Unread 11-01-2012, 22:46
Ahh, yes. I was doing that from memory and see the M12 now. As for the photos, I would like to check with the folks who that field belongs to first. In the meantime, can someone else put up photos?
Greg McKaskle
Unread 12-01-2012, 01:28
robokiller robokiller is offline
AKA: Jaxon Weis
FRC #2757 (B.A.D.)
robokiller is an unknown quantity at this point
I was playing around with the reflectors and the kinect and found that at any distance the reflectors appeared to be out of range on the depth finder. Is it possible that the IR emitter and receiver are just far enough apart that the IR light is reflected back to the IR emitter and not being picked up by the IR receiver.
-- Jaxon Weis
Unread 12-01-2012, 04:38
-- Jaxon Weis
The Kinect "Out of Range" can happen in both directions. Having an object too close, or washing the IR grid out with another IR source will give you "out of range" readings on the depth feed. Using OpenKinect or another package which can access the raw IR image may result in more success.
Unread 12-01-2012, 06:59
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Originally Posted by DjMaddius View Post
If you use the example tracker you can easily modify it to your needs. I believe tracking will win or loose the game this year. You either auto track the entire time so you can make baskets 90% of the time or you dont track and maybe get 10% of the baskets. Its going to be a difficult feet for everyone but every year there is a win or loose situation and I believe thats this years.
Personally, we are doing complete auto tracking. Trajectory planning and all in the code. Going for a 80% scoring throw from anywhere on the field. But really this depends a LOT on the mechanical also. They have to get the thrower throwing consistently before I can do any math to predict where it will land.
I want my team heading for ghe same thing. I think it will be a must as I cant see aiming and judging distance with a human from 40 feet away is gonna be to easy.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 12-01-2012, 09:42
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
This is a source of disagreement between me and one of the mentors on my team. I completely agree with you. If we had many shots to try it would be one thing but with only three balls I feel the robot has to be able to either take the shot itself, or provide distance data accurately for a human to line the shot up. I think the only way for a human to do it without serious camera assistance is if they design the bot to shoot from set positions and just work themselves into those positions. Trying to eyeball both shot angle and power from across the court is going to be very hard.
-Mike
Unread 12-01-2012, 17:10
dellagd's Avatar
AKA: Griffin D
-Mike
What part of your team are you on? Programming, Drive systems or Gaming systems?
Unread 12-01-2012, 17:28
I'm one of the mentors. This discussion came up outside the students work and just between us as we were talking about the challenge.
Unread 12-01-2012, 17:51
Izz1324 Izz1324 is offline
FRC #3642
Izz1324 is an unknown quantity at this point
Can the sensor that sees the reflective tape judge the distance and height of the tape?
Unread 12-01-2012, 21:30
CastleBravo CastleBravo is offline
CastleBravo is an unknown quantity at this point
Yes, the camera (with proper image processing) can determine the distance, direction, height, etc of the vision target if the retro-reflective tape on the target is properly illuminated.
Unread 13-01-2012, 06:46
dellagd's Avatar
AKA: Griffin D
By using the slant of its sides while looking at it from an angle? I hope that method can be accurate
