Go to Post The numbers that I gave were purely theoretical and should not be considered realistic - Karibou [more]
Unread 12-01-2012, 17:51
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: Jaguars and rc?
Both Jaguar and Victor have similar front ends on the PWM interface; they both use opto-isolators. The difference is likely in the resistor value used and resulting current drawn from the PWM signal source.
If you use a Jaguar for this application, you'll need to recalibrate it since the range of the PWM signal is wider on the Jaguar than a normal RC PWM signal, and if left uncalibrated you will not get full output at the full RC PWM range (1.0 .. 2.0 ms). The Jaguar range is optimized to work with the cRIO.
And if you move it from your project back to a cRIO run robot, don't forget to re-re-calibrate it
Unread 12-01-2012, 18:22
AKA: Scott McMahon
Re: Jaguars and rc?
Someone with better insight than I w.r.t. the Victor's front end pointed out that the opto-isolators used on the Jag and Victor are not the same and this is the main difference.
I still stand by the advice on re- and re-re- calibrating.
