Go to Post “There are two ways to compete, one is to drag your opponent down, the other is to raise the bar and excel. Which do you think is more beneficial to you in the long run?” -- John Abele - Candice.E [more]
Unread 12-01-2012, 19:55
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Kinect Won't work
I installed the Kinect Beta, the Microsoft Visual 2010 C# Express, and it won't work with the skeletal veiwer or the driver station.
When I open the skeletal viewer, I get the message "Could not create DIrect3D surface. Please ensure the DirectX runtime is instelled." So I installed the DirectX runtime, but I get the same error.
What do?
Unread 12-01-2012, 19:56
Re: Kinect Won't work
What do?
Try the Skeletal Viewer - WPF example instead.
Unread 12-01-2012, 19:58
Lead Programmer
AKA: Josh
The Kinect Sample game sort of works though, so I don't know whats up.
Unread 12-01-2012, 20:00
The Skeletal Viewer example (non-WPF version) uses hardware DirectX acceleration. If your graphics card doesn't support the necessary features, it won't run.
Unread 13-01-2012, 17:22
Lead Programmer
AKA: Josh
So... What is the wpf and where can I get it?
Also, showdn't the netbook be able to use the kinect if it's included in the kit?
Unread 13-01-2012, 17:34
It can. Use the Skeletal Viewer WPF example located at C:\Program Files\Microsoft SDKs\Kinect\v1.0 Beta2\Samples\bin
Unread 13-01-2012, 17:59
Lead Programmer
AKA: Josh
Ok, so that worked, but the driver station still can't find the kinect
Unread 13-01-2012, 18:01
Have you installed the Kinect Server? It can be found in the WPILib project at firstforge.wpi.edu if not.
