Go to Post You will forever be confronted with choosing between right and wrong, or choosing what you think you can get away with. Which way you go defines what kind of person you are. Choose wisely. - Gary Dillard [more]
Unread 09-01-2012, 00:44
NXTGeek's Avatar
NXTGeek NXTGeek is offline
AKA: Malachi
NXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to behold
webcam object tracker with pan
Does anybody have experience with a system that uses the pan webcam module to track an object, like the top basketball hoop's reflective tape, regardless of the direction the robot is facing?
Unread 09-01-2012, 07:52
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
I did some prototyping, a while back using a pan camera but did not find it particularly useful. have you tried this yet?
Mike B
Unread 09-01-2012, 08:05
Re: webcam object tracker with pan
It looks like andymark still sells the pan/tilt assembly used a few years ago with the Axis camera.
Greg Mckaskle
Unread 09-01-2012, 09:53
If you do use that pan tilt assembly, make sure that you insulate the camera from the robot frame. The back of the Axis camera is connected to the camera's ground, and can provide a sneaky violation of the frame isolation rules.
Unread 12-01-2012, 21:07
NXTGeek's Avatar
AKA: Malachi
I'm asking if anyone has successfully programmed the webcam to track something, and for the webcam to pan when the object it is tracking starts to go off the screen (ie robot turning). I would use this (1) so that the driver will always know what direction to turn to be head-on with the basket, or even better (2) having the ball launcher swivel so it is always facing the top basket, and adding an ir range finder to semi or fully automate the shooting angle.
Unread 13-01-2012, 08:23
If you have the pan tilt assembly from 2009 and a target, there is an example in the vision folder that does this. You can also see videos of teams doing it that year, such as http://m.youtube.com/index?desktop_u...?v=M84hL57QUvg
Greg Mckaskle
Unread 13-01-2012, 14:14
NXTGeek's Avatar
AKA: Malachi
Cool Re: webcam object tracker with pan
Greg Mckaskle
That is definitely isn't the right link, but thanks anyway, I'll search youtube.
Unread 14-01-2012, 05:49
Yohan's Avatar
Yohan Yohan is offline
AKA: John P
FRC #0368 (TKM.368 (Team Kika Mana))
Yohan is on a distinguished road
Greg Mckaskle
For desktop users: http://www.youtube.com/watch?v=M84hL57QUvg
Unread 14-01-2012, 08:44
Sorry about that, I was using an iPad and did a copy/paste and trusted that it would work. The attached video is one of the many movies showing the pan/tilt used to track a color. Note that the target that year was a combination of fabrics, and the results on the field were not nearly as good as in the lower light environments.
Greg McKaskle
