Go to Post Great people like you both [Scott and Libby Ritchie] make the FIRST community even better! - tiffany34990 [more]
Unread 11-01-2012, 17:38
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Hebrew is an unknown quantity at this point
Crio not found
I am attempting to the run the imager tool but the crio is not being found. i am using the yellow cable and the subnet is set to 255.255.255.0. any fixes?
Unread 11-01-2012, 19:53
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Crio not found
There are similar threads on the forum that describe debugging techniques, so be sure to search.
Here are some things to try:
1. Make sure all other network connections on the computer are turned off.
2. Put a switch between the computer and the cRIO, you can use the DLINK radio as the switch.
3. Try using a different computer
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 11-01-2012, 23:55
twiggzee twiggzee is offline
FRC #3502 (Octo-(PI)-Rates)
twiggzee is an unknown quantity at this point
Re: Crio not found
We had the same problem, then my kids saw that FIRST released an update saying that the yellow cable was not the right one. we found our CROSSOVER cable from last year and connected it. it found our cRio. however, now we're getting errors....
Wendy
Team 3502
Unread 12-01-2012, 00:12
Re: Crio not found
I don't have a quick answer, but if you want to dig into this and learn a lot, the threads listed here are worth reading:
http://www.chiefdelphi.com/forums/sh...12#post1103212
Unread 12-01-2012, 08:44
Re: Crio not found
i should have looked before i spoke, but the team update is about a different cable, not the yellow crossover cable like i said earlier. either way, we used a different cable (not the yellow one provided in the kit) and it worked.
Wendy
Team 3502
Unread 12-01-2012, 09:21
Re: Crio not found
Is there a special way to use the router as a switch or do I just put the Ethernet into port 1 and the yellow cable into port 2?
Unread 12-01-2012, 21:32
Mary Johnson Mary Johnson is offline
Mentor Programming
FRC #3958 (Schrodinger's Cat)
Mary Johnson has a spectacular aura aboutMary Johnson has a spectacular aura aboutMary Johnson has a spectacular aura about
Re: Crio not found
I am having a similar problem. My FRC Imaging Tool from last year can communicate with the cRIO from last year, but the new 2012 FRC Imaging Tool cannot. (It's complicated. I am a rookie team but borrowing a cRIO from last year) I am using a regular ethernet cable. Should I be using a "yellow crossover cable" instead? Will that make a difference? Any other ideas? I have been struggling with this literally all day.
Mary Johnson
Team FRC3958
Mom & Programming Mentor
Unread 13-01-2012, 22:39
Re: Crio not found
The only suggestions I can give are just repeats of what's been posted before. Most importantly, disable every network interface except the one you're using to communicate with the cRIO.
