Go to Post The pie is as large as you make it. - boomergeek [more]
Unread 12-01-2012, 19:10
HFCHS-NASA HFCHS-NASA is offline
FRC #4207
HFCHS-NASA is an unknown quantity at this point
Re: Using a Plunger System to Launch Balls
We are trying to avoid pneumatics because we want to have the precise control of electric motors. How does a spring and cam system work? That sounds what we want to do.
Unread 12-01-2012, 19:14
http://www.chiefdelphi.com/media/photos/31538
http://www.chiefdelphi.com/media/photos/31539
That should get you started on some things of that nature.
Unread 12-01-2012, 21:50
pfreivald's Avatar
AKA: Patrick Freivald
A cam is just a plate or something of the sort with an irregular shape. You attach it to an output shaft (geared up/down as necessary) and use it to stretch a spring or other elastic material (surgical tubing, for example). As it goes around, the object slips off of the cam and slams to equilibrium position. You can stop the cam each revolution using a sensor of some kind, so it doesn't fire continuously.
This video, http://www.youtube.com/watch?v=_hTyXQUgYLE at 1:49 shows a cam-powered kicker running.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 13-01-2012, 10:34
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
we messed with a pneumatic/spring plunger mechanism and we couldn't figure out how to make the ball fly farther than 10 feet without dumping our entire tank. If you find a way to do it well, please share!
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 14-01-2012, 14:37
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Our team was thinking of using a plunger system to launch balls...
After some brainstorming, I think this is a solid approach. I was thinking that the plunger end would be cupped, holds the ball and not require contact cylinder walls.
Most of the launch systems I've seen use apposed spinning disks like:
http://www.youtube.com/watch?v=l8U9u2iqMEs While this works, I think getting good accuracy will be technically challenging. Note the "slice" behavior (Magnus effect) of the ball in some of the shots. Variable control of launch velocity and symmetric launching will be much more technically challenging than simply pushing the ball in a straight line. The pro/cons for plunger are:
PROS:
  • Inherently shoots straight
  • Simple mechanism for guiding the plunger
  • Velocity control simplified by displacement based adjustment of spring loading
CONS:
  • Ball load mechanism is more complex
  • Cocking (spring pre-load) and trigger mechanism more complex
  • Cycle time for each ball much greater than disk design
Given how short each tournament is and the game design, I think that shooting from midcourt with a high shot percentage will be key to high scoring.
Unread 15-01-2012, 18:51
DavisDad's Avatar
MechE
I made a prototype to see how the spring loaded shooter would work. Pretty much a big pinball machine design. I used a heavy duty door closer spring. Pulling back about 40 lb force, I launched the ball a whopping 8 feet.
If the goal is to shoot from behind the mid court line, ~ 25 feet, it'd take "cocking" the spring to more than 160 lb. Too scary for me. The recoil at 40 lb was pretty violent.
Also, my son says springs are verboten on his team.
Unread 15-01-2012, 20:43
pfreivald's Avatar
That kind of recoil wouldn't exactly produce the level of accuracy you'd be looking for on a half-court shot, either!
Team 1551
I write books, too!
Unread 15-01-2012, 21:51
DavisDad's Avatar
MechE
Recoil isn't really the right term. The ball is gone when the rod and spring reach the end of their travel. There's a lot of inertia in the mechanism when it slams into the end-stop.
Unread 15-01-2012, 23:09
pfreivald's Avatar
"Shimmy"?
Team 1551
I write books, too!
Unread 19-01-2012, 07:03
DavisDad's Avatar
MechE
Found this: http://www.youtube.com/watch?v=j6Jzsv2OKAY
http://www.youtube.com/watch?v=l8iqG...eature=related
