Go to Post I'm gonna laugh when the GDC numbers the first official game hint #3. - Racer26 [more]
Unread 18-12-2002, 20:12
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Bugs, new features: help!
Well, I just finished all my finals and have nothing to do until Jan 4. Therefore, I've decided to spend some time fixing up ALL of my programs (RoboEmu, RoboGUI, RoboCon, RoboIDE, gDash) with bug fixes and improvements.
However, I need your help (yes, you!). Here are the current bug lists and proposed features for these programs:
Bugs:
RoboEmu:
  • Illegal Instruction while quitting under XP
  • Doesn't recognize labels with a ":"
  • Can't have variables with NOT in their name
  • Won't recognize BRANCH without a space before [
  • Random errors under XP
  • Doesn't automatically add the correct extension when saving Projects
  • Linux version complains about min/max during compile on many systems
  • Doesn't report when it's out of commands (hangs)
RoboGUI:
  • Outputs two $STAMP directives
  • Bad line breaks
  • File handle stays open too long
  • Pump code doesn't put a ":" after label
  • Doesn't check 26-variable limit
RoboIDE:
Hangs after choosing Run on some systems
RoboCon:
Doesn't properly re-sync after loss of signal
Proposed Features:
RoboEmu:
  • Support for EduBot code
  • Reset for joysticks
  • Renamable Joysticks
  • Ability to move controls around the screen
RoboGUI:
none
RoboIDE:
  • Find/replace
  • Copy/paste
  • Save As...
  • Keyboard shortcuts
RoboCon:
none
All:
Documentation!
Anybody have anything else? Any bugs I missed? Any other features you'd like to see? Other programs you'd find usefull?
--Rob
Unread 19-12-2002, 02:14
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Bugs, new features: help!
How about a version that runs on a Mac under OS X? (and can download code to the RC!)
-dave
Y = AX^2 + BX + C
Unread 19-12-2002, 11:08
At the risk of making promises I can't keep, I'll work on it. Most of my code, especially RoboIDE, is fairly portable assuming I can find the gnome libraries for Mac OSX so the only real changes should be to the dynamic library code, but even that is just a few lines.
Anything else?
Unread 19-12-2002, 15:44
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Careful, you said it was easy, now it will most likely be very difficult.
Matt Krass
Unread 19-12-2002, 18:14
Wouldn't it be a whole lot easier if Dave provided you with a mac with OSX?
As far as libraries go, check out http://fink.sf.net
I've done hardly more then compile RoboIDE. Rather then spending a lot of time writing your own editor, wouldn't it be easier to "plugin" an existing editor, such as vim or emacs (or even gedit)
Unread 19-12-2002, 19:05
omg. That is amazing. I found the gnome libraries on that fink site, and I just found an iMac of the dead-sexy LCD/OSX variety, and now all I need is a comiler, so I'm off to find gcc... Given the RoboIDE contains zero code specific to Linux with the exception of dynamic libraries, life should be very easy now.
Anybody happen to know how macs name serial ports or how to load dynamic link libraries? Or at least a good place to look?
--Rob
Unread 19-12-2002, 19:33
OS X comes with GCC (3.1 in Jaguar, I believe). It may not be installed by default, though.
http://developer.apple.com/tools/macosxtools.html
Unread 20-12-2002, 12:17
Well, I've hit a bit of a snag. It turns out the iMac I'm using only has OSX 10.1.2 and pretty much everything requires 10.2 (Jaguar). I ordered the upgrade from Apple, but it may not get here for awhile.
Anyway, anybody else have any other bugs, features, or programs they'd like? If not, I'll start fixing stuff this weekend and hopefully have releases ready by early next week.
--Rob
Unread 23-12-2002, 13:29
Last call for suggestions! I just finished the changes to RoboGUI and am very close to having RoboEmu fixed up. If there are ANY other suggestions or bug reports, now is the time as I won't be revisiting these programs any time soon unless the new control system breaks them; there just isn't time during the build season to invest in programming anything other than PBASIC.
Again, if there is anything, no matter how outrageous or stupid it sounds, that you would like to see, let me know. I try to write these programs so they are as useful as possible, but I need help in figuring out what people actually want/need.
Email Bugs Brandon Martus Announcements 0 07-03-2003 22:53
YM magazine features BUZZ Kathryn General Forum 1 14-08-2002 00:31
CAD Drawings? archiver 1999 17 23-06-2002 22:35
AutoCAD 2002 David Kelly Inventor 7 24-06-2001 09:11
