Go to Post so, i want the clue now, okay? is it bad that i am more interested in this years game than i am in taking my finals next week? - jwfoss [more]
Unread 12-01-2012, 16:48
2479crazyfirst 2479crazyfirst is offline
FRC #2479
2479crazyfirst is an unknown quantity at this point
Battery
Hi, our team was wondering if the battery had to be in a up right postion on the robot or could it be at a side or an angle? We could not find anything in the manual.
Thanks for any help!
Unread 12-01-2012, 16:50
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Battery
There is no orientation rule. There is however somewhere a rule that defines how long the battery wires to breaker can be before they count as official weight. (1ft i think?)
-Duke
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 12-01-2012, 17:09
FRC #2479
Talking Re: Battery
Ok thank you so much!!
Unread 12-01-2012, 17:14
FRC #2479
Re: Battery
Out of curiostity do you know if we can have rope lights on our bots? like those xmas lights in a tube?
Unread 12-01-2012, 17:20
Re: Battery
[R03-A], and 12" does in fact equal 1'. Note that this isn't the length to breaker, however; it's the length to the Anderson connector.
With respect to rope lights, I'd say those fall under Non-Functional Decoration and suggest looking at those rules.
Unread 12-01-2012, 19:32
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Battery
In reply to battery orientation there are two aspects to take into account for a correct answer here, battery specs and robot rules.
For the battery specs, because it is an AGM battery, you can place the batteries in any orientation and not have a diminished performance because of the orientation. As for the game and robot rules, there are no rules to restrict you from placing the battery in any orientation on you robot, but i will give you the following recommendations for best performance on the robot.
  • Do not place tension on the anderson half connects wires. Make sure there is enough slack where you do not have taught cables.
  • While not having taught cables, you still want the minimal amount of 6# wire connecting to the battery to reduce resistance.
  • Do not orientate the robot where the top of the battery is blocked. There are vents for the cells under the top cover, blocking these can result in cell failure or battery rupture.
  • Do not leave exposed lugs or have the battery able to short between the lugs on your robot. Meaning do not place the battery where it can shift and contact exposed metal.
  • Many teams like to either velcro or ziptie the Anderson half connectors together during the match. This is a good practice so the connectors will not just disconnect during a match.
  • Always make sure the battery is mounted in place on the robot where it can not shift or be ejected during rough game play.
Also a couple good practices to prolong the life and performance of the batteries are:
  • Do not carry the batteries by the cables. This will put overstrain on the lugs and can cause cell failure.
  • Always charge in a well vented area.
  • Do not use alligator clips to charge with. Splice in Anderson quick connectors onto the charger to minimize wear and damage to the terminals on the battery half of the Anderson quick connectors.
  • Insulate all areas where connections are made, including the terminal hardware.
  • Always check battery terminal hardware and cables before use. Never use a battery with loose or improperly connected hardware to it.
  • Always use a smart charger to charge these batteries with, so overcharging does not occur.
Obviously these are not all inclusive lists but good practices with respect to the battery.
-Michael Dessingue
Unread 12-01-2012, 19:49
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Battery
You can, just make sure to abide by [R05] and [R08] (i.e. don't put them on a shiny disco ball).
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 12-01-2012, 22:22
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Battery
Originally Posted by dez250 View Post
[*]Do not orientate the robot where the top of the battery is blocked. There are vents for the cells under the top cover, blocking these can result in cell failure or battery rupture.
For the same reason, don't install the battery upside down. Any other direction (upright, on its side, flat) is fine.
Unread 12-01-2012, 22:37
Re: Battery
If one reads the manufacturer's sheet on this battery it would lead to believe that you can mount and use the battery in any orientation. I would suggest that upside down is a bad idea because you can't see the insulation that should cover the terminals and you can't see if the terminals are under stress. Please remember that the metal terminal that is sticking out of the red and black plastic on your battery is simply soldered to a round terminal inside the battery. Any stress can damage or break this connection. This is not a repairable fault. While the batteries we use are AGM and theoretically have the acid impregnated in a glass mat, I recommend that teams do not charge them upside down. This is just good practice to prevent some of the problems already listed.
Unread 12-01-2012, 22:43
sometimestommy's Avatar
sometimestommy sometimestommy is offline
Schrödinger's Assistant
AKA: Thomas Moll
FRC #1939 (Ku-Nig-Its)
sometimestommy is on a distinguished road
Re: Battery
I believe so, Last year we had leds, in our back panel of lexan. I would check the rules for sure. but make sure that it wont get caught in any moving parts or other robots for that matter.
-Thomas
Unread 12-01-2012, 22:48
Re: Battery
For the battery specs, because it is a gel-cell battery, you can place the batteries in any orientation and not have a diminished performance because of the orientation.
Gel and AGM are different technologies.
Unread 13-01-2012, 13:47
Re: Battery
Whoops, thank you for pointing out the typo, updated.
-Michael Dessingue
Unread 13-01-2012, 15:04
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: Battery
Everyone knows not to put the battery in upside down. All the electrons will fall out when you disconnect it. Or is that what that AndyMark plastic plug is for?
Unread 13-01-2012, 15:37
kaliken kaliken is offline
294 Old Fart Mentor...
AKA: Ken S
kaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant future
Re: Battery
Actually its not far from the truth.. in 2010 our battery was installed with a downward slope (Terminals downward made the cable connection run much shorter) Well lo and behold after one match we noticed something that looked little damp in the battery carrier after removing the battery... Very carefully we checked with a little bit of baking soda and yup the battery had leaked. From that point on batteries are always right side up. Having a leaky battery is not something you want to deal with during competition.
2010 World Champions! Newton Alliance Captain: Many thanks to 67 and 177 for the amazing ride
Unread 13-01-2012, 23:32
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
Re: Battery
I wouldn't stress a few extra inches of #6 wire to make for better mounting. 1000' of #6 wire has a resistance 0.3951 ohms. Even at a 50 amp draw, 6' of #6 gauge wire has less than 0.25 volts drop. I'm not saying be wasteful by any means, just that if you need an extra inch or two to make a better robot, it's worth taking it. Go here to play with values to see what your losses will be:
http://genuinedealz.com/voltage-drop.html
-Mike
