Go to Post Stupid rules are still rules. They're not meant to be broken, they're meant to be changed. - Alan Anderson [more]
Unread 12-01-2012, 22:56
missledojer217's Avatar
missledojer217 missledojer217 is offline
FRC #3230 (Prototype X)
missledojer217 is infamous around these partsmissledojer217 is infamous around these partsmissledojer217 is infamous around these parts
loader ideas
anyone have any loader ideas for the balls
Do not mess with me...
For you are crunchy and... taste good with... Uh... Ketchup
"Drink Mountain Dew, Eat Pizza, Make Robot, This is Life."
Unread 12-01-2012, 23:10
Mr. Pockets's Avatar
Mr. Pockets Mr. Pockets is offline
Optimist Alumnus
AKA: Nathan
FRC #1189 (Gearheads)
Mr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond repute
Re: loader ideas
We're probably going to use some sort of roller. Basically you just have a spinning rod a few inches off the ground that pulls game pieces in as they touch the spinning roller. I recommend experimenting with different heights and materials to optimize it, but I can guarantee from experience that the general concept works great.
Another concept that I was kicking around a few days ago was a set of two arms that would extend out of your bot to the ground, tighten together around a ball caught in the middle, and lift back up to deposit in a hopper or shooter. Much slower and more complicated than a roller, but it could be useful for manipulating the bridge as well if you build it right.
Just a few for right now, might post more if any pop up.
Cheers
Year 1: Learned about Projects
Year 2: Learned about People
Year 3: Learned about Pride
Year 4: Learned about Promise
I came to robotics for the robot, but stayed for the people
2012/13 Melancholic retiree and wistful dreamer
Unread 12-01-2012, 23:20
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: loader ideas
Same, we're using an idea we've found tried and tested from both 2006 and 2009: Polycord belting and sending it through a series of conveyors/elevators/whatever-you-want-to-call-them type applications. We're also thinking of feeding them directly to a shooter, as the 3 ball limit sorta makes a hopper a moot point.
Hope your season goes well.
-Cal
Academic Student (Forever)
Unread 02-02-2012, 16:50
landybr landybr is offline
FRC #1676
landybr is an unknown quantity at this point
Re: loader ideas
great ideas
Unread 02-02-2012, 18:15
Re: loader ideas
Thanks this really helpful. My team is being really slow on this concept.
Unread 02-02-2012, 22:59
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: loader ideas
Be careful, two arms sounds like two appendages which is not legal. According the latest official Q&A, at ANY point in time when something is breaking the plane of the vertical projection of the frame perimeter, it must be at most one contiguous assembly, contiguous at points outside the frame perimeter. So you have to be careful about how you extend those two arms out... they better be touching at the fingers, or something similar to that.
Game - The Game » Robot Actions » G21
Q. Our question is similar to FRC1540. We want to put surgical tubing "whips" on a roller located at the frame perimeter. When this rotates the whips will extend beyond the frame perimeter. Is each "whip" its own apendage or is the assembly considered one appendage?
A. If multiple items exit the Frame Perimeter and are not contiguous outside the Frame Perimeter, they are considered multiple appendages.
... and....
Q: To prevent differing interpretations of G21 and the following Q&As on appendages could you address the legality of a appendage BRIEFLY crossing the frame perimeter in multiple places during deployment? For example, a "H" shaped appendage might cross in two places as it quickly folds out.
A. Any time the appendage is outside the Frame Perimeter, it must be a contiguous piece.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
