Go to Post According to that logic, Engineers would say there will be twice as many spectators as needed, and we all know that's not the case! - Taylor [more]
Unread 12-01-2012, 23:18
470-RBTX's Avatar
470-RBTX 470-RBTX is offline
Team Schmooze Captain
FRC #0470 (Alpha Omega Robotics)
470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of
Re: Moving Battery
Our team is using a program that moves our chassis up or down the bridge in correlation to which side of the bridge it is on and the angle of the chassis compared to the direction of gravity, the technique is being called "dithering" by our mentors.
Unread 12-01-2012, 23:21
andycolletta andycolletta is offline
FRC #2102 (Team Paradox)
andycolletta is an unknown quantity at this point
Re: Moving Battery
are you using a gyro for this?
Unread 13-01-2012, 15:54
dsirovica's Avatar
dsirovica dsirovica is offline
Programming and Electrical Mentor
AKA: Dean Sirovica
FRC #1458 (Red Ties)
dsirovica is on a distinguished road
Re: Moving Battery
We had the same idea. Thanks for the great comments.
How "fine" can the regular drive-train CIMs move the robot without a "low" gear. Can they do 0.5" steps? Or do we need a separate mechanism for fine adjustments? (sorry for the newbie Q)
On the angle/gravity autonomous action, make sure you don't start oscillating, or just the music up & we'll have a dance
Dean
Unread 13-01-2012, 18:32
yassi yassi is offline
FRC #3636
yassi is an unknown quantity at this point
Re: Moving Battery
Thanks for the replies. We've decided against moving the battery, we're pretty sure.
Unread 16-01-2012, 07:45
Re: Moving Battery
Dean
Dean,
The CIM motor has more than the three poles that the FP motors have but the amount that any motor can move an object is dependent on the gear reduction ratio as well. While some motors offer better fine control, you should have no problem getting a CIM fine tuned to 1/2". You might want to look at the AM gear motor or a seat or a door motor for this application.
