Go to Post Adam, when most of us look at your robots, we aren't thinking, "How Creative!" What we are thinking is more like, "Holy Crap!" - Richard Wallace [more]
Unread 12-01-2012, 23:22
Mr. Pockets's Avatar
Mr. Pockets Mr. Pockets is offline
Optimist Alumnus
AKA: Nathan
FRC #1189 (Gearheads)
Mr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond repute
Re: Robot-Appendage Balancing
This is a brilliantly creative idea!
Have you considered attaching outward facing metal half-pipe shaped grooves or attachments to the base of your superstructure, and sliding grippy wheels into said grooves? You could then power those wheels to slide the position of your superstructure. You might also consider having some sort of little piston at each end to stop the structure from shifting until the endgame.
Cool idea btw, even if you don't end up using it. Rock on!
Year 1: Learned about Projects
Year 2: Learned about People
Year 3: Learned about Pride
Year 4: Learned about Promise
I came to robotics for the robot, but stayed for the people
2012/13 Melancholic retiree and wistful dreamer
Unread 12-01-2012, 23:25
ipburbank ipburbank is offline
President
FRC #0639 (Code Red Robotics)
ipburbank is an unknown quantity at this point
How do you plan on going about doing this?
I don't know that we will be using it, but my initial thought on how to do it would be to use a lead screw (probably with a window motor) and slide it on rails. This would allow the robot to be solidly fixed during a match while allowing for control during operation.
Thanks, Istvan.
