Go to Post To the ball knockers, I salute you. - Brandon Holley [more]
Unread 12-01-2012, 23:31
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
2386 prototype shooter
Just a preliminary test on a prototype, should be a fun year!
http://www.flickr.com/photos/wileyb-j/6688012541/
Unread 12-01-2012, 23:41
Kenichi's Avatar
Kenichi Kenichi is offline
AKA: Williamson j.a. Marshall
FRC #1056
Kenichi has a little shameless behaviour in the past
Re: 2386 prototype shooter
very nice! but are you willing to sacrifice a cim motor for your shooter?
Team 1056
Unread 12-01-2012, 23:43
WileyB-J's Avatar
FRC #4976 (Rebels)
Hell no! Its rather easy to "make" a cim and we plan on doing that! Just a first run with an idea.
Unread 12-01-2012, 23:44
FRC3883FRC's Avatar
FRC3883FRC FRC3883FRC is offline
FRC #3883 (Data Bits)
FRC3883FRC has a spectacular aura aboutFRC3883FRC has a spectacular aura aboutFRC3883FRC has a spectacular aura about
Thats one big issue with using a cim motor for ball tossing. As of rule [r38] it limits the robot to olny 4 cim motors. Thats why my team is trying to use pneumatics for launching the ball to the hoops. Still looked very good. Nice job.
Team 3883, The DATA BITS!
!!!MN State Champs 2012!!!
Unread 12-01-2012, 23:46
krazyman1013's Avatar
krazyman1013 krazyman1013 is offline
FRC #0701 (RoboVikes)
krazyman1013 is an unknown quantity at this point
I like it but does it only have a single degree for aiming?
Unread 12-01-2012, 23:47
WileyB-J's Avatar
FRC #4976 (Rebels)
Nope! Still have a few cards on my chest!
Unread 12-01-2012, 23:51
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
There are CIM-ulators and CIM-Sim gear boxes that allow you to use a "5th CIM" but it's just a rs-775 or a FP with a gear box. It does give you the same output RPMs of a regular CIM.
Unread 12-01-2012, 23:53
WileyB-J's Avatar
FRC #4976 (Rebels)
You are correct! Run a 775 at a 2.7:1 ratio and bam! Cim-u-lation.
Unread 12-01-2012, 23:56
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
I'm kind of curious what the weight of that flywheel is. That is some impressive distance. I really like the simplicity of this prototype.
Unread 13-01-2012, 00:30
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
My question(s) how long does that take to spin up?
And how many balls can you feed though it before it slows down significantly?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 13-01-2012, 02:55
Aren Siekmeier's Avatar
on walkabout
^ This.
Because, am I seeing correctly that you are driving the wheels directly off the CIM? Certainly not totally ridiculous, but I would expect it to have a little more trouble accelerating the ball than is observed.
Unread 13-01-2012, 08:40
ThaineP
Posts: n/a
I think you'll notice a bit of an erratic spin difference between different launch speeds with the static bar. My team is doing something similar, but with two sets of wheels, one on the top and one on the bottom so we can control spin if needed.
Nice job.
Unread 13-01-2012, 09:02
Chris is me's Avatar
AKA: Pinecone
Nice job.
With a longer ball path, you can put more backspin (or topspin if you have an inverted shooter) on the ball. Simpler than software!
Unread 13-01-2012, 09:12
Tazlikesrobots's Avatar
Tazlikesrobots Tazlikesrobots is offline
Jack of all trades...Master of none
AKA: Robert
FRC #1745 (P-51 Mustangs)
Tazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud of
Send a message via Yahoo to Tazlikesrobots
Nice shot
It is all mind over matter....If you don't mind, it does not matter.
_________________
2006 Woodie Flowers Award Recipient - Lone Star Regional
2006 Rookie All-Star - Lone Star Regional
2007 Lone Star Regional Champions
2008 Quarter-finalist - Lone Star Regional
2009 Chairman's Award & Website Award - Dallas Regional
2009 Quarter-finalist - Dallas Regional
2010 - Xerox Creativity Award & Semi-finalist - Dallas Regional
Unread 13-01-2012, 09:24
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
In terms of the cim-u-lation, wouldn't torque play a factor, because those motors, even with the gearbox, have a nominal amount of torque
