Go to Post Actually, FIRST Is hoping the reverse, that your bot will be "Ball damage proof" - Rombus [more]
Unread 10-01-2012, 17:44
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: "assisted" balance
Originally Posted by Basel A View Post
The first team update says:
Emphasis mine. While I think it was clear that this was the initial intent of the rules, now the intent matches the rule itself. No touching the ground!
A third robot can still assist balancing for two other robots, though, based on these rules.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 10-01-2012, 19:05
Jimmy K's Avatar
Jimmy K Jimmy K is offline
FRC #1002 (Circuit Runners)
Jimmy K is an unknown quantity at this point
"A Bridge will count as Balanced if it is within 5° of horizontal and any Robots touching it are fully supported by it." -- Team Update 1
So the third bot cannot help with balancing the bridge (unless it is doing so without touching the bridge i.e. telepathically ).
EDIT: Referenced the quote as coming from the team update.
Unread 10-01-2012, 19:08
Ninja_Bait's Avatar
AKA: Jake Potter
Oh, wow, you're right. I totally misread that.
Unread 10-01-2012, 19:56
Kraftyman Kraftyman is offline
FRC #0847 (PHRED)
Kraftyman is an unknown quantity at this point
Can you reference the manual?
Mine does not state those words together.....
KraftyMan
newbie mentor for Nypro Oregon
Unread 10-01-2012, 20:15
firemaster193's Avatar
firemaster193 firemaster193 is offline
FRC #2130
firemaster193 is an unknown quantity at this point
but in coopertition points could you grasp an opposing robot
Unread 10-01-2012, 20:34
The first Team Update was released today. In the past they have been released on Tuesdays and Fridays by ~5:00pm Eastern.
Unread 12-01-2012, 10:35
bhaidet's Avatar
bhaidet bhaidet is offline
FRC #0435
bhaidet is an unknown quantity at this point
I think that even another robot on the ground would qualify as "support" so they pretty much killed all hope of getting around the rule with the last update.
Unread 12-01-2012, 13:39
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Originally Posted by LabVIEW Rocks! View Post
Im pretty sure you can grab an alliance robot, but not an opponet robot. But be sure and read the rules carefully first.
Not entirely accurate. The rule concerning contact with an opponent robot, <G27>, states: "Deliberate or damaging contact with an opponent Robot inside its Frame Perimeter is not allowed." <G26> may also apply in some situations: "Strategies aimed at the destruction, attachment, damage, tipping or entanglement of Robots are not in the spirit of
the FRC and are not allowed."
Thus if you contacted the opposing robot outside of its frame perimeter (say, its bumpers) in a way not aimed at the destruction, attachment, damage, tipping or entanglement of any robot, you may well be legal.
Unread 12-01-2012, 23:05
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
The kick off video shows bots grabbing each other when balancing 3 bots on a bridge. The trick is going to figure out - in advance - how to hold onto the other bot. Unless grab points are defined in advance, how can you plan for grabbing?
When you are balancing 2 bots on a bridge, there is enough room that you do not need to touch the other bot.
Unread 12-01-2012, 23:37
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
The video is never a reliable source. They also have the robots holding basketballs and using them to balance, clearly in violation of [G14].
[G14]
Strategies that use Basketballs to either aid or inhibit Balancing of any Bridge are not allowed.
Violation: Technical-Foul, and counting or discounting the affected Bridge as Balanced, as appropriate.
Unread 13-01-2012, 00:13
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
So you can incur the technical-foul by touching your opponent's bridge WITHOUT interfering with balancing (so no red card and it doesn't count). Then, a Robot touching it won't be fully supported and they'll lose the 10-20 points.
Although I guess that "the act of balancing" refers to that technically as well.
Unread 13-01-2012, 18:19
Siri's Avatar
Dare greatly
Note that outside-the-frame perimeter grabbing for coopertition purposes appears to have been made legal by Team Update 2. <G26> now does not apply for this situation, as it reads:
Originally Posted by TU2
Strategies aimed at the destruction or inhibition of Robots, via attachment, damage, tipping or entanglement of Robots are not in the spirit of the FRC and are not allowed.
Bumper it up!
