Go to Post When it comes to FIRST (you've all heard the cliche) -- we're all winners. When it comes to the competition: to the engineering design challenge, we're NOT all winners -- some solutions are better than others. - JVN [more]
Unread 12-01-2012, 14:54
JohnA888 JohnA888 is offline
Team 888 Web Monitor
FRC #0888 (Robotiators)
JohnA888 is an unknown quantity at this point
The holes in the bridge are for?
"The top surface of each bridge includes and array of 15 small holes, details of which are included in the official field drawings." I have seen the drawings and was wondering what the purpose of the holes were. Anyone have any ideas?
Unread 12-01-2012, 15:02
Shu2137's Avatar
Shu2137 Shu2137 is offline
AKA: Andrew Shumaker
FRC #2137 (TORC)
Shu2137 is an unknown quantity at this point
Re: The holes in the bridge are for?
They are there to hold the balls from rolling around pre-match. Not saying they could not be used for anything else...
Unread 12-01-2012, 15:19
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Well, that makes sense. And a maximum of 14 balls can be held on the Coopertition ramp, so the 15 fits there.
Unread 12-01-2012, 16:41
PiManIII PiManIII is offline
FRC #0114
Team Role: Webmaster
PiManIII is an unknown quantity at this point
Where can I find these dimensions? I tried looking in the manual, but there are no specific dimensions. Any thoughts?
Unread 12-01-2012, 16:45
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
You need to look at the field drawings for specific dimensions.
Unread 12-01-2012, 16:49
FRC #0114
After looking through all of that material, I still could not locate the size of the holes and the proper spacing. I'm assuming that the holes are predrilled when given to fields, but how can we replicate this with our version (plywood)?
Unread 12-01-2012, 16:57
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Game Specific Drawings - Sheet number GE 12095 - page 106 in the pdf file.
Unread 12-01-2012, 17:05
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
The holes are 1-1/8" diameter, and will wind up being 1/8" deep. At that depth, it's probably just to steady the balls at the beginning of the match.
- Steve
Unread 13-01-2012, 02:01
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I didn't even think it would be for steadying the balls at the beginning of the match. The manual *I believe* is very vague as to the position of the placement of the balls, but this COULD be a possibility. Random placements at the beginning of the match (ala 2005 tetra placements at the start of a match) maybe?
Aside from that discussion, my first thought for the purpose behind the holes (which I'm surprised no one brought up yet) would be a deterrent to add a vacuum suction cup to the bottom of your robot to hold yourself in place.
This was assumed by myself & some of my other veteran team members from experiencing first hand teams doing this in the past for games (2006 actually comes to mind - or any other year with a surface similar to the plastic(ish) top of this year's ramps.
Do the "holes" actually go all the way go through the top most ramp material to let air/other things fall through, or are they just countersinks?
Unread 13-01-2012, 02:16
Aren Siekmeier's Avatar
on walkabout
The field drawings show them as thru holes in the top layer of polycarbonate.
Unread 13-01-2012, 02:26
Well then... My first impression is the one I'm sticking with. A deterrent for attaching yourself to the ramp permanently at any time during the match with a suction cup of any kind.
Unread 13-01-2012, 02:42
on walkabout
There is already <G10> making attaching to field structures illegal, so this might already be covered. Besides, what advantage would anchoring yourself with a sunction cup present? You are now unable to adjust your wait to facilitate balancing, and you got up there in the first place so tipping is hopefully not a concern.
It seems very likely to me that the holes are for the balls.
Unread 13-01-2012, 02:46
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
I think it would help because presumably the best strategy to balance 2 robots is to get one in about the right position and move the other one around. The suction cup would mean the one staying still wouldn't slide. It would also be helpful if you had a movable mass on your robot.
Unread 13-01-2012, 13:11
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
The holes are for ball placement.
Q. Re: [G05] Where specifically are the Basketballs placed on each bridge? Is each alliance allowed to select the position of the 2 balls on their own alliance bridge? Where are unused Basketballs allotted to Robots placed on the Coopertition Bridge? Where are the 2 “regular” Coopertition Bridge
A. Balls will be placed in any of the 15 holes in the surface of the Bridge. Exact locations are not specifically defined and will be determined by the field reset crew at the event.
Suction cups are not legal.
Q. If a robot attaches suction cups to the bridge, is that considered grappling a field element?
A. This would be a violation of Rule [G10].
Unread 13-01-2012, 13:18
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Oh ye of little imagination...
With 3 robots on the bridge, no robot can move in order to balance. Thus the only way to account for differences in weight & c.g. would be to have an arm or slide that can transfer a little bit of weight from one side to the other. It's also much more precise than driving.
Don't think robots will have arms this year? I suspect many teams will have bridge lowering mechanisms powered by motors.
"Quick! Everyone lean left!"
GitHub
