Go to Post Look at 71's 'walking' bot from last year. One dosn't need wheels/track to move. All you need is an idea. - Jack [more]
Unread 12-01-2012, 21:13
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Gears?
Hey Everyone,
What's the smallest and largest gears you can find that fit on the CIM Motor?
Also, do you know the smallest and largest gears that fit on other provided motors?
Thanks
Unread 13-01-2012, 00:02
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
Re: Gears?
The smallest gear depends on the diameter of the shaft which limits the practical diameter of the gear. As far as the largest gear, there theoretically is no limit since you could have a very large gear with the appropriate shaft hole to fit the motor shaft. How practical a five-foot diameter gear on a CIM would be, I don't know.
To find a good selection of gears in the range you might be interested in, check the gear catalog from Stock Drive Products. That would give you an idea of what is out there in the size you might be looking for.
http://www.sdp-si.com/estore/CoverPg/Gears.htm
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 13-01-2012, 06:47
ksafin's Avatar
AKA: Kirill Safin
Re: Gears?
Well, I meant specifically sized to the shaft of the provided CIM motors
Unread 13-01-2012, 07:18
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Re: Gears?
AndyMark has a few to choose from, 12T, 14T, and 15T
Unread 13-01-2012, 12:25
FRC #3573 (Ohms)
Re: Gears?
Gears may be bored out to a larger diameter to fit the motor shaft, so if you buy a gear with a slightly smaller bore, you have a vast selection available from places like Stock Drive Products.
Dr. Bob
