Go to Post As we all know, a low Center of Gravity is a beautiful thing. - Andy Baker [more]
Unread 12-01-2012, 23:20
korsuk19's Avatar
korsuk19 korsuk19 is offline
FRC #3734 (Caxy's)
korsuk19 is an unknown quantity at this point
Coding for CIM Motor help
Hello, I am the new programmer for my team, but I'm not all that great yet.
Right now I have to code to make our CIM motor's drive. I have to make it so that the left motors are controlled by the left joystick and right motors to be controlled by the right joy stick. This is my question.
I've been coding for tank drive, but would arcade be easier?
This is the code I have.
File Type: java test.java (594 Bytes, 29 views)
just wanna learn
Unread 13-01-2012, 09:18
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Re: Coding for CIM Motor help
Typically teams use tank drive but it is really personal choice, i belive you could simplify your code a bit to by using:
Your Mainclass:
RobotDrive drive;
Joystick left, right;
robotInit:
drive = new RobotDrive(1,2,3,4); // Four motors on pwm You can replace with CANJaguars too.
right = new Joystick(1);
left = new Joystick(2);
operatorControl:
drive.tankDrive(left.getY(), right.getY());
For arcade:
drive.arcadeDrive(left.getY(), left.getX()); // your Y val is your speed and the X value is your turning
You may have to import classes if so just right click the underlined errors and click fix imports
Unread 13-01-2012, 10:28
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
If you're using NetBeans, there is a shortcut (default Ctrl+Shift+I) which automatically fixes imports. VERY handy.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 13-01-2012, 14:34
FRC #0228 (Gus)
Yes true and i <3 netbeans
