Go to Post I just think the teams that will be winners will have a higher score then us :) - Kyle [more]
Unread 12-01-2012, 22:06
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
PID Timing
If seems to me that PID Loops are time dependent. After all, you have the derivative term which is essentially monitoring the change in your error term.
My question then, is why the derivative term isn't normalized for time (divided by the loop timing) to account for loops changing speed. In the past, we've not used "D" terms, but it seems that when the cpu starts to get loaded down, the D term could cause issues due to varying loop timing.
Am I off base?
Unread 13-01-2012, 02:13
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: PID Timing
No... it doesn't sound like you are off base. Are you sure the the PID is not time compensated?
Unread 13-01-2012, 02:54
Tom Line's Avatar
Re: PID Timing
Well, we've always written our PID's by ourselves. The math is trivial and it's good for the kids to understand where they come from. Not a single paper I've read on PID calculation states as an assumption that the loop needs to be consistently timed. That's why I'm curious if we can improve our PID loops by incorporating a time normalization into the derivative term.
Unread 13-01-2012, 07:07
Re: PID Timing
See attached screenshot.
Unread 13-01-2012, 09:21
Re: PID Timing
How are you calculating the derivative if you aren't taking into account the actual loop time? Same for the integral.
Unread 13-01-2012, 09:43
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Re: PID Timing
Things are easier if you use a "fixed dt". This means you should execute your PID algorithm at a fixed rate. Example, run the loop every 10ms or every 100ms. Otherwise you do need to adjust your gains for the time since you last ran the loop every time you run the loop.
Unread 13-01-2012, 21:31
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: PID Timing
Two solutions:
-Calculate DT with a tick count, shift register/feedback node, and subtract.
-Use a timed RT loop to guarantee time. You can not care about the dt because it is constant. Time in PID will then be counted in iterations instead of milliseconds, which is fine.
I am currently doing the second. It seems to be working well so far.
Kettering Motorsports
Unread 13-01-2012, 21:36
Re: PID Timing
http://www.chiefdelphi.com/forums/sh...64&postcount=3
