Go to Post Two students with no clue but enough dedication to work on something is always better than one expert who doesn't care enough not to leaveit until the last day. - Matt Krass [more]
Unread 13-01-2012, 10:59
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Re: Chassis Lift alternative, getting over barrier
tri-wheels are elegant when to come to high powered robots that only climb stairs but
but is terms of the our games they are wicked overkill even in 2004 they were
the killer part in my mind is the affect on acceleration and the ability to turn
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 16-01-2012, 12:11
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
We mounted the 8"ers on the c-channel bits, but have had some issues actually getting the robot running. Here is a pic of the bot under construction.
Unread 16-01-2012, 13:04
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
A tri-wheel drivetrain would be a bit heavier and thus diminish acceleration for a given powertrain, but I don't think it would be detrimental or even all that noticeable. And I don't see how a tri-wheel setup would turn any differently as compared to an 8WD with equivalent geometry.
Can you explain your thoughts?
Unread 16-01-2012, 13:06
Chris is me's Avatar
AKA: Pinecone
Do keep in mind that the barrier is steel. You may find it difficult to climb up for this reason alone - test on an actual bump.
Unread 16-01-2012, 14:03
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
We're also going to experiment with skid plates to help raise the incident wheels a bit.
I think this is going to pretty much kill the idea of using only 2 CIMs.
If it takes more than 2-3 seconds to cross a barrier we'll probably be facing an opponent blocker, and we'll need all the torque we can muster.
Unread 21-01-2012, 23:30
mrlg220's Avatar
mrlg220 mrlg220 is offline
FRC #3464 (Sim-City)
mrlg220 is an unknown quantity at this point
Hmm... For the skid plate, could you possibly use some simple 80/20 corner brackets? Considering that there is overhang before the front wheel, your frame will approach the barrier first. Now, if you bolt the bracket just in front of the wheel on both sides would that 45 degree angle of approach be enough to raise the bot over the bump?
Unread 21-01-2012, 23:46
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
Skid plates are out. Since we are doing a wide frame, we need the wheels as close to the front and back as possible. This leaves little room for a skid plate.
On a wooden mock-up of the barrier the robot did poorly, but our weight distribution was also poor. Battery was all the way in the back, so the bot got stuck straddling the barrier. Going to try centering the battery, and then pneumatic wheels (shipping).
