Go to Post The scent of a smoking Globe motor is familiar to many. - Alan Anderson [more]
Unread 13-01-2012, 10:46
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Failed comms to cRIO
So here's our situation. CRIO is fully imaged, DS is updated to version 11.30.11. We have attempted to connect via the port 1 on the cRIO and through our D-Link.
Crazy Part begins here:
We are able to ping both the cRIO and the D-Link, but we are not getting Robot comms (although the "Robot" light is on in the driver station).
We are thinking it's the D-Link (when I reset the D-Link, wireless setup page is blank, and there is option to set it up manually either). Have we missed a firmware update?
Also, last years robot (which for the time being, our control board has not changed) was driving the week of Christmas.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 13-01-2012, 11:03
bdbayes bdbayes is offline
Captain
FRC #2927 (Pi Rho Techs)
bdbayes is a jewel in the roughbdbayes is a jewel in the roughbdbayes is a jewel in the rough
Re: Failed comms to cRIO
What programming language are you using?
Are you saying that it says that the robot is connected via the driver station?
If so, does it show that you have code loaded?
After last year at competition, we found that the abilities to edit the configuration on the D-LINK were limited. We have yet to solve this problem.
Unread 13-01-2012, 12:06
Zuelu562's Avatar
AKA: Jake Janssens
We are coding in C++ via Windriver. The main part of the driver station says we have no comms (and therefore, the robot code light can't light up) yet, we can ping the robot and the D-Link.
Team Resume
Volunteer Resume:
Unread 13-01-2012, 14:54
Captain
Can you try wiring directly into the cRIO and then deploying your code?
Can you then try to connect with the driver station application?
Unread 13-01-2012, 14:57
It needs to. The module order has been shuffled around. See page 23 of the C++ Getting Started Guide.
Unread 13-01-2012, 15:12
You are using an incompatible web browser. That's what gives a blank wireless page.
Try it with IE.
Unread 13-01-2012, 17:34
Captain
Since the cRIO II is now among the valid options this year, they have changed the order of the modules to accommodate fewer modules. Even if you are using original cRIO, you need to correct the order of the modules before reimaging the cRIO.
