Go to Post [I]'Twas the night before ship day, And all through the shop, Not a creature was stirring, Not even[/I] -- Naah, they'll never believe that. - GaryVoshol [more]
Unread 13-01-2012, 12:24
eat4fun's Avatar
eat4fun eat4fun is offline
sudoer
AKA: Eric Bryce
FRC #1325 (Inverse Paradox)
eat4fun is an unknown quantity at this point
Jags not taking data
Hey guys,
We’re having trouble with our CompactRIO; specifically, Jaguars are not responsive to data from the driver station. I wrote a piece of LabVIEW code to run the Jaguars either using joystick inputs or using a numerical constant (0.5). However, upon deploying this code to the cRIO, there was no indication that the code was running.
To ensure that the code was in fact running, I wrote a bit of LabVIEW code to set the value of the Jag to 0.5, and then to get the value of the speed controller and compare it to the input. I observed that while the value of 0.5 was being sent to the Jag, I was not getting the same value when I get the output of the speed controller. This leads me to believe that it is a programming error.
I have attached printscreens of the code I am using. It is not changed at all from the default code except for the actual motor code. I have also checked with different Jaguars, breakout boards, and sidecars to no avail. I have also probed the PWM ports manually with a multimeter (can't afford an oscilloscope), it does not read any significant signal on either the power, ground, or signal cables.
Thanks,
Eric
Unread 13-01-2012, 13:04
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
This might sound silly, but are there are errors on the driver station? i assume you are using teleop mode
Mike B
Unread 13-01-2012, 13:34
Re: Jags not taking data
Is your Digital Module in Slot 2 of your cRIO?
Unread 13-01-2012, 13:35
NeatNit's Avatar
NeatNit NeatNit is offline
Alumni Programmer
FRC #1577 (Steampunk)
NeatNit is an unknown quantity at this point
Well, in cases like this the problem is usually a silly one. In this case I want you to try a few things:
1. Make sure you enable TeleOp in the Driver Station... I can't tell you how many times this was my problem
2. Create a DIO Out and make it toggle every half second while in TeleOp (regardless of motor output). Put a small LED or something in it if you can, or just check it with a multimeter. This will be a guarantee that the code is running and the sidecar is working.
3. Try different PWM ports, Just to make sure. Also, see a wiring diagram to make sure it's wired correctly. (I can't find one to link to atm)
4. Look for a FRC example for controlling a Jaguar and see if that works.
If the Jaguars are receiving signals, they will flash red or green (according to the direction). If they flash and the motors still don't move, the problem lies in the motor or the connection between the Jaguar and the motor, or the motor is faulty.
By the way: if you will notice, there's a global variable "LED toggle rate (ms)" which is used to flash the User LED in Periodic Tasks. Make sure to remove that if you plan on using the User LED.
Also post here any errors you see in the Diagnostics tab.
Unread 13-01-2012, 14:18
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Make sure you performed the fix for the DB37 cable found here:
http://www.usfirst.org/sites/default...structions.pdf
The views expressed are mine and should not be construed to represent the views of anyone else.
