Go to Post But frankincense and myrrh will come in handy after your team starts to smell during that first design meeting. - Jessica Boucher [more]
Unread 13-01-2012, 11:15
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
Width of a tank tread
What width would you think would be optimal for a tank type tread for a bot?
Unread 13-01-2012, 11:18
BAM BAM is offline
FRC #2425
BAM is an unknown quantity at this point
Re: Width of a tank tread
I would advise against treads for these reasons:
Tread gets expensive. If you buy plastic tread, it's most likely coming from the UK (long shipping time), and isn't that durable. If you make tread (see this article: http://blog.makezine.com/2010/10/27/...s-from-roller/) it can be very time consuming and heavy. If you use a conveyer belt type material, it's easy for it to slip and come off the rollers. I hope you take this into consideration, all the best,
-B
Unread 13-01-2012, 11:37
compman90's Avatar
compman90 compman90 is offline
AKA: Logan Dillinger
FRC #1448 (Parsons Vikings)
compman90 is an unknown quantity at this point
Talking Re: Width of a tank tread
You could always use a belt that has some pretty good teeth in it, and Using pulleys to rout the belt. Could make a pretty decent and cheep tank tread. Also go to auto shops they usually have a pretty good selection.
Unread 13-01-2012, 12:43
keneajer's Avatar
keneajer keneajer is offline
AKA: Jerome (JJ) Kenealy
FRC #1091 (Oriole Assault)
keneajer is an unknown quantity at this point
one year our team use a snowmobiles tracks. We didn't use the whole track but one side but if you go with snowmobiles tracks your need to use there wheels.
Unread 13-01-2012, 12:54
markle22 markle22 is offline
FRC #3511
markle22 is an unknown quantity at this point
where would you find the track and the wheels for this?
Unread 13-01-2012, 13:18
czeke czeke is offline
Tool and Die maker/Tool Designer
AKA: Carl Zechel
czeke has a spectacular aura aboutczeke has a spectacular aura about
In Breakaway, our team used snowmobile belts for our tank tread system. An old, used snowmobile tread was used. We removed the cleats and bandsawed the outer sides away, leaving the inside groove in the middle. Our belts was 2 1/4" wide. We shortened the belt to fit the cogged wheels ( 2 driver wheels in the front and 2 idler wheels in the back. We also used, on each side, in the middle between the cogged wheels, on the inside, 2 bogey wheels, which had to be shimmed out about 3/4", similar to your WCD. The bogeys were 10" center to center, and we achieved very good maneuverability. By gearing it down, we picked up extra torque. Instead of being pushed around, we did the pushing. We also easily traversed the humped playing field dividers.
Unread 13-01-2012, 13:39
FRC #3511
Thanks for the info.
