Go to Post Chit Chat is frivilous but CD would be a colder place without it. - Koko Ed [more]
Unread 13-01-2012, 13:00
The Crop? The Crop? is offline
FRC #3475 (The Crop?)
The Crop? is an unknown quantity at this point
Conveyer Belts
We'er looking at using a conveyer belt to load our shooter. But we were wondering what would be best, using 1 or 2 belts?
Unread 13-01-2012, 13:03
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Re: Conveyer Belts
please describe how you would be using the two belts
Unread 13-01-2012, 13:21
Re: Conveyer Belts
We are thinking of having the motors running the conveyer belt on both the top and bottom of a (magazine) channel leading to the shooter. The channel would be at a slight (15/20 degree) angle
Unread 13-01-2012, 13:29
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Conveyer Belts
With a single belt and a fixed surface the balls can rotate against each other and bind up, so you need to control how closely they're spaced apart.
With two belts there is no such problem, but the mechanism is heavier.
Unread 13-01-2012, 13:30
Re: Conveyer Belts
is it hard to get the belts sinked? or does it not matter?
Unread 13-01-2012, 13:32
DevonRea DevonRea is offline
FRC #2363
DevonRea is an unknown quantity at this point
Re: Conveyer Belts
We used a single conveyer belt pickup in 2009 with a board on one side to apply pressure as not to fall. The lunacy balls were covered in cloth(which slipped when rubbed together) as apposed to this year's balls which are extremely grippy when rubbed together. With a single conveyer belt the balls need to roll up the other side so when two balls come in contact it'll get in the way of the system working. This year we're probably gonna go with a double conveyer belt system ourselves but I’m sure you’d be able to make a single belt system work somehow too. Good luck!
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: Conveyer Belts
Do you mean "synchonized"?
Not terribly important if they're traveling about the same speed. I assume you're going to use a high-traction, flat belt though.
Chexposito's Avatar
AKA: Expo
FRC #1730
Re: Conveyer Belts
they work better when they are close in speed. it really doesn't matter if they're perfectly in sync.
