Go to Post me: "Was I on fire!?" Roberto: "Sure you were. We only let you burn for about 10 seconds.":yikes: - El Geffe [more]
Unread 13-01-2012, 13:25
TofuRama TofuRama is offline
01000110 01010010 01000011
AKA: Matt
FRC #2484 (Team Implosion)
TofuRama is an unknown quantity at this point
Re: Can't connect to the camera
Thanks! We're no longer getting any errors. Also, how do we get the video onto our driver station?
Unread 13-01-2012, 13:48
The default dashboard is set up to expect the camera at 10.xx.yy.11. To use the camera in the configuration you have it, you will have to install LabVIEW, create a dashboard project, change the camera IP, build the Dashboard and use your new Dashboard.A possibly easier option would be to set up the camera to plug into the robot radio as described on Page 27 of Getting Started with the 2012 FRC Control System.
Unread 13-01-2012, 13:51
AKA: Matt
Thanks!
Unread 13-01-2012, 13:54
Thanks!
If you go with the camera->Robot radio option, you can take the IP back out of your GetInstance call as the robot radio configuration appears to be the new default looking at AxisCamera.cpp and AxisCameraParams.cpp
