Go to Post The game objectives are still the same, get boxes into your scoring zone, stack approximately half of them, run for the top of the ramp. So lets sit down, shut up, and start building robots. - ChrisH [more]
Unread 13-01-2012, 12:20
UriF UriF is offline
FRC #2213
UriF is an unknown quantity at this point
Is this legal?
Hey.
Is it possible (or legal) to use a windows application in addition to the Dashboard, that communicates with the cRIO?
My intention is writing a program in windows that will take the camera images from the cRIO, apply some image processing code, and send some data back to the cRIO.
Unread 13-01-2012, 12:51
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Re: Is this legal?
which programming language are you using?
Unread 13-01-2012, 12:58
Jared Russell's Avatar
Taking a year (mostly) off
Re: Is this legal?
Yes, this is possible and, assuming all other rules are followed, legal. If you look at the SmartDashboard project on FIRST Forge (http://firstforge.wpi.edu/sf/projects/smartdashboard), you will see that there is the ability to customize the SmartDashboard to perform image processing. The full documentation is still in process, but you should be able to skim through the code and see how it is working.
Unread 13-01-2012, 13:02
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Is this legal?
It appears to be in a grey area. The only rule I could find that fits this situation is R80.
Originally Posted by R80
The Driver Station software provided on the Kit of Parts website is the only tool permitted to specify and communicate the operating mode (i.e. Autonomous/Teleop) and operating state (enable/disable) to the Robot. The Driver Station software must be revision 01.07.12.00 or newer.
I would suggest to post your question to the FRC Q&A Forum.
-Michael Dessingue
Unread 13-01-2012, 13:26
FRC #2213
Re: Is this legal?
C/C++ for writing the windows application.
Unread 13-01-2012, 13:28
Chexposito's Avatar
AKA: Expo
FRC #1730
Re: Is this legal?
is this true for the robot as well?
Unread 13-01-2012, 13:41
FRC #2213
Re: Is this legal?
Yes.
Unread 13-01-2012, 13:50
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
Re: Is this legal?
R80 just says that the software you write may NOT control the operating mode or state. If can do a whole heck of a lot of other stuff, like all of the dashboard functionality or image processing. R58 says "teams are expected to customize their Dashboard code."
Adding digital control over aiming your shooting mechanism after target has been acquired sounds like a good idea.
