Go to Post It's up to veteran teams and mentors to help keep the original spirit of FIRST alive. - It's up to us to make these boards exemplify the FIRST principals in every post. - Ben Mitchell [more]
Unread 13-01-2012, 15:56
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Can't load code into Crio
Our team recently reflashed our crio with the 2012 image. Also, we wiped our classmate and then downloaded and installed all the latest 2012 software. Since reformatting the classmate we have been unable to deploy code to the robot. The robots ip is set to 10.2.24.2 (team 224) and our computers ip is set automatically using the driverstation. According to the manuals everything is configured correctly. When the classmate is connected to the crio the robot communications light is green and robot code is red, due to the flash. We are using the FRC plugin in netbeans and code in java.
The build always fails and gives us the following error:
C:\Users\Developer\sunspotfrcsdk\ant\upgrade.xml : 40:
java.net.ConnectException: Connection timed out: connect
If anyone has any clue how to make this work then your help will be greatly appreciated.
We are using last years Crio if that matters
Unread 13-01-2012, 16:40
mathgeek0001's Avatar
mathgeek0001 mathgeek0001 is offline
Commander Arctangent
FRC #1759
mathgeek0001 is an unknown quantity at this point
Re: Can't load code into Crio
Are you using the access point or crossover cable?
Unread 13-01-2012, 16:41
FRC #1747
Both
Neither worked and ip settings were correct
Unread 13-01-2012, 16:44
Sounds like something is blocking Netbeans. Try turning off the firewall.
Unread 13-01-2012, 17:12
dave1027 dave1027 is offline
FRC #1027
dave1027 will become famous soon enough
Have you specified your team number inside netbeans?
Under Tools -> Options, Miscellaneous click on FRC Configuration and enter your team number.
that's how netbeans knows where to send the code.
Unread 13-01-2012, 17:39
FRC #1747
Yeah thats been done
Unread 13-01-2012, 23:02
FRC #1747
We are running NetBeans 7.1
Based upon a post found here, I figure that I try downgrading to 6.9.1
I'll let you guys know once I get to school tomorrow to try it out
Unread 14-01-2012, 19:19
FRC #1747
Ok, so it was a combination of things
Partially because the firewall was blocking Netbeans, and that the plugins needed a reinstall
