Go to Post Our team's worst moment was the 13 years of FIRST's existence in which it did not exist. - Joe G. [more]
Unread 12-01-2012, 19:55
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Kinect Won't work
I installed the Kinect Beta, the Microsoft Visual 2010 C# Express, and it won't work with the skeletal veiwer or the driver station.
When I open the skeletal viewer, I get the message "Could not create DIrect3D surface. Please ensure the DirectX runtime is instelled." So I installed the DirectX runtime, but I get the same error.
What do?
Unread 12-01-2012, 19:56
Re: Kinect Won't work
What do?
Try the Skeletal Viewer - WPF example instead.
Unread 12-01-2012, 19:58
Lead Programmer
AKA: Josh
The Kinect Sample game sort of works though, so I don't know whats up.
Unread 12-01-2012, 20:00
The Skeletal Viewer example (non-WPF version) uses hardware DirectX acceleration. If your graphics card doesn't support the necessary features, it won't run.
Unread 13-01-2012, 17:22
Lead Programmer
AKA: Josh
So... What is the wpf and where can I get it?
Also, showdn't the netbook be able to use the kinect if it's included in the kit?
Unread 13-01-2012, 17:34
It can. Use the Skeletal Viewer WPF example located at C:\Program Files\Microsoft SDKs\Kinect\v1.0 Beta2\Samples\bin
Unread 13-01-2012, 17:59
Lead Programmer
AKA: Josh
Ok, so that worked, but the driver station still can't find the kinect
Unread 13-01-2012, 18:01
Have you installed the Kinect Server? It can be found in the WPILib project at firstforge.wpi.edu if not.
