Go to Post If you never reach out and experiment with different things, you will never have the courage to reach out again. It's only through experiments and experiences where we get to understand ourselves better. - Ken Leung [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 13-01-2012, 19:53
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: BlackJaguar-99.bin issues
Originally Posted by kccowan View Post
From the 2CAN firmware utility, it says the 2CAN firmware is 2.5. The bootloader version is 1.1. Man rev (not sure what that is) says 1.3 and Man Date 12/12/2009.
Firmware version 2.18 is the latest for FRC but 2.5 should work fine.
Am I running the right stuff?
Yes.
At some point, I saw the 2CAN light be red (flashing, if memory serves).
A red LED means you do not have CAN connectivity, bad cabling, bad termination resistor. If the 2CAN LED is intermittent between green and red then you have an intermittent can connectivity issue, you may confirm this in the web dash by viewing the CAN tx/rx error counter. If the error counter is incrementing you have a CAN connectivity problem.
Do you recommend that we disconnect the bus so that only 1 Jag is on the bus at a time when we flash?
I have never had a problem updating JAG firmware with multiple JAG's on the BUS as long as they each have a unique ID, however when you are trying to troubleshoot, it is always a good idea to make the problem as simple as possible.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 13-01-2012, 23:18
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Team 857 is having a very similar issue. Our grey jags had v92, and we tried today to update to v101. Attempting to flash resulted in timeout errors, and after a few attempts, the light on the jags turned off. We have not yet tried the new black jags.
I tried flashing v92 back on, but the same timeouts occurred. We did then update the 2CAN from v2.1 to v2.18. Still no success. The CAN always flashed green after booting.
Unread 13-01-2012, 23:42
kccowan kccowan is offline
AKA: Ken Cowan
FRC #1073
kccowan is an unknown quantity at this point
We were able to go back to V92 easily. I'm not sure if it helps, but we power cycled frequently during the whole process.
KC
Unread 14-01-2012, 09:47
How many Jags are on the BUS when attempting to flash?
What is the TX/RX error count in the 2CAN web dash and is it incrementing?
Mike Copioli
