Go to Post "Its never too late to be inspired" - Alex Golec [more]
Unread 13-01-2012, 20:04
swootton swootton is offline
AKA: Steve Wootton
FRC #4055 (NRG4055)
swootton is on a distinguished road
Re: Error Deploying JAVA
OK guys, here's the whole log file for the build and run. This the default sample code from the getting started with java.
Please review and help!!!
init:
init:
Deleting directory C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\build
Deleting directory C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite
Deleting directory C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\j2meclasses
clean:
Created dir: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\build
Compiling 1 source file to C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\build
compile:
Created dir: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\j2meclasses
preverify:
Created dir: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite
Building jar: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite\RobotTemplateFirstDrive1_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
Romizer processed 96 classes and generated 4 files.
Expanding: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite\RobotTemplateFirstDrive1_1.0.0.jar into C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite
Moving 1 file to C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite
Deleting: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\image.suite.api
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) Client VM 20.5-b03
Target IP: 10.40.55.2
Network interfaces on host:
Realtek PCIe GBE Family Controller: address: 10.40.55.6 netmask: 255.255.255.255 or hidden by IPv6 address (due to Java on Windows Bug:6707289)
Connecting FTP @10.40.55.2
upgrade:
Sending local file image.suite
flashapp:
deploy:
debug-run:
do-debug-run:
[cRIO] [OTA Server] ********* REBOOTING cRIO *********
[cRIO]
Waiting for cRIO to reboot (1s)
Waiting for cRIO to reboot (2s)
Waiting for cRIO to reboot (3s)
Waiting for cRIO to reboot (4s)
Waiting for cRIO to reboot (5s)
Waiting for cRIO to reboot (6s)
Waiting for cRIO to reboot (7s)
[cRIO]
Connect debugger attempt 1
Connecting NetBeans debugger
Start debug proxy
init:
Trying to connect to VM on socket://10.40.55.2:2800
Attached JPDA debugger to localhost:2900
Failed to establish connection with VM: Connection refused: connect - trying again in 5 seconds...
[cRIO] -> * Loading debug.o: debug
[cRIO] Debugging is up, target server mounted at /tsfs
[cRIO]
[cRIO]
[cRIO] VxWorks
[cRIO]
[cRIO] Copyright 1984-2006 Wind River Systems, Inc.
[cRIO]
[cRIO] CPU: cRIO-FRC II
[cRIO] Runtime Name: VxWorks
[cRIO] Runtime Version: 6.3
[cRIO] BSP version: 1.0/0
[cRIO] Created: Jun 2 2011, 16:29:00
[cRIO] ED&R Policy Mode: Deployed
[cRIO] WDB Comm Type: WDB_COMM_END
[cRIO] WDB: Ready.
[cRIO]
[cRIO] * Loading nisysrpc.out: nisysrpc
[cRIO] * Loading NiRioRpc.out: NiRioRpc
[cRIO] * Loading nivissvc.out: nivissvc
[cRIO] * Loading nivision.out: nivision
[cRIO] NI-RIO Server 4.0.0b8 started successfully.
[cRIO] task 0xeb6cf8 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
[cRIO] * Loading visa32.out: visa32
[cRIO] * Loading niserial.out: niserial
[cRIO] * Loading sysstatepublisher.out: sysstatepublisher
[cRIO] task 0xfc9b00 (ServerAds.Lookup) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0xff2178 (ServerAds.Lookup) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x163af30 (ServerAds.Lookup) deleted: errno=0 (0) status=0 (0)
[cRIO] * Loading RTWebServer.out: RTWebServer
[cRIO] System Web Server started
[cRIO] * Loading NiFpgaLv.out: NiFpgaLv
[cRIO] task 0x25f3f20 (tNiDsc0) deleted: errno=13893648 (0xd40010) status=0 (0)
[cRIO] * Loading FRC_FPGA.out: FRC_FPGA
[cRIO] * Loading FRC_NetworkCommunication.out: FRC_NetworkCommunication
[cRIO] FRC_NetworkCommunication was compiled from SVN revision 2923
[cRIO] FPGA Hardware GUID: 0x1394F6DC1FEB42EC6910E5767ED1D22C
[cRIO] FPGA Software GUID: 0x1394F6DC1FEB42EC6910E5767ED1D22C
[cRIO] FPGA Hardware Version: 2012
[cRIO] FPGA Software Version: 2012
[cRIO] FPGA Hardware Revision: 1.6.4
[cRIO] FPGA Software Revision: 1.6.4
[cRIO] * Loading FRC_JavaVM.out: FRC_JavaVM
[cRIO]
[cRIO]
[cRIO] [OTA Server] Version: 2012 FRC, Jan 5 2012, 17:20:48
[cRIO]
[cRIO]
[cRIO] Welcome to LabVIEW Real-Time 11.0rc14
[cRIO] task 0xeaea58 (sysapi-rpc) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO] [Squawk VM] Version: 2011 FRC, Nov 5 2011, 14:34:13
[cRIO] [Squawk VM] File SQUAWK_DEBUG_ENABLED found, starting squawk in debug mode...
[cRIO] Listening for connection from proxy on serversocket://:2800
Established connection to VM (handshake took 16ms)
[cRIO] FPGA Hardware GUID: 0x1394f6dc1feb42ec6910e5767ed1d22c
[cRIO] FPGA Software GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9
[cRIO] DIO LoopTiming: 260, expecting: 261
Waiting for connection from debugger on serversocket://:2900
[cRIO] task 0x25b3c80 (System Web Services Load Thread) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x2856198 (mDNS resolve) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x2beb2f8 (mDNS resolve) deleted: errno=0 (0) status=0 (0)
