Go to Post If I had a mul-let then I'd look like Andy Baker used to and that would be ba-ad, really ba-ad. - JaneYoung [more]
Unread 13-01-2012, 18:53
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Jaguars - Current Mode Fails
Our Logomotion robot's drivetrain is controlled by four Jaguars - two master Jaguars and two slave Jaguars on each side. They are Black Jaguars connected by CAN, with speed PID control. We had synchronized the masters and slaves with voltage mode in the past, but we read somewhere that using current mode shares the work load more efficiently. So while using that robot to test some new code, we tried using current mode and found problems with both the getter and setter current methods.
jagLeftMaster.changeControlMode(CANJaguar.ControlMode.kPercentVBus);
jagRightMaster.changeControlMode(CANJaguar.ControlMode.kPercentVBus);
jagLeftMaster.changeControlMode(CANJaguar.ControlMode.kCurrent);
jagRightMaster.changeControlMode(CANJaguar.ControlMode.kCurrent);
jagLeftMaster.getOutputCurrent(); //both of these only return the absolute value of the current
jagRightMaster.getOutputCurrent();
jagLeftSlave.setX(jagLeftMaster.getOutputCurrent());
jagRightSlave.setX(jagRightMaster.getOutputCurrent()); //these don't appear to do anything at all
The getOutputCurrent method only returns the absolute value. The number itself looks accurate but is only ever positive.
The setX() method while in Current mode isn't appearing to do anything. The LED on the Jaguar is solid amber - it is communicating via CAN but is not receiving instructions.
Has anybody had these problems before and/or know what the problem is?
Thanks in advance.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 13-01-2012, 19:23
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Jaguars - Current Mode Fails
Have you set the PID constants for current mode? The default is all 0s & it will just sit there.
Unread 13-01-2012, 20:01
The slaves do not and never have relied on PID loops - they draw straight from the masters.
tough.exit();
Unread 13-01-2012, 20:14
Current mode uses PID.
Unread 13-01-2012, 22:34
Exclusively? For our purposes, it is not only impractical but also not healthy for the motors, as ideally the slaves should be running at the same speed as the masters.
If they use PID exclusively, is it not true that Current mode is more effective at distributing the work load?
tough.exit();
Unread 13-01-2012, 23:03
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
They use a PID loops to get the current draw as close to the target as possible. Remember, the output is some speed from -1 to 1. The Jaguar needs the PID loop to figure out what output will get the proper current draw.
Unread 14-01-2012, 07:41
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Does anyone have any experience trying to get a "slave" CIM to sync current output with a "master" CIM - specifically in the application of a 4-motor (2 per side) drivetrain?
I'm curious what ballpark PID values were used, and what your tuning methodology was.
We're planning on using the speed control PID on the master Jags. If there is a PID loop running on the slave Jags just to match the currents, if it doesn't react fast enough, it'll confuse the master Jag's speed PID loop. Sort of like trying to hit a constantly moving target.
Has anyone already implemented something similar to this?
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 14-01-2012, 08:33
FRC #1700
If I had to do this, I would have the PID control on the master jaguar, then take whatever that PID loop is outputing, and set the slave to that value (no PID loop on the slave jaguars). I had to use two motors to control a fully connected crab drive last year, and this method worked well for it.
Unread 14-01-2012, 09:11
That sounds like what we were doing before - we had the slave Jaguars running in PercentVBus mode, and the master Jaguars running in PID speed control mode. We had separate PID loops on the left and right master Jaguars. To synchronize the slaves, we used:
jagLeftSlave.setX(jagLeftMaster.getOutputVoltage() / jagLeftMaster.getBusVoltage());
jagRightSlave.setX(jagRightMaster.getOutputVoltage() / jagRightMaster.getBusVoltage());
Is something similar to this not possible in current mode?
tough.exit();
Unread 14-01-2012, 21:04
FRC #1700
Exclamation Re: Jaguars - Current Mode Fails
No, you can't have the same speed and current guaranteed at the same time; you need to pick one.
