Go to Post Eating at Pappy's is the only St Louis activity for me. - Cory [more]
Unread 13-01-2012, 20:32
adrianfarmer's Avatar
adrianfarmer adrianfarmer is offline
FRC #3556
adrianfarmer is an unknown quantity at this point
Question Automatic limit switch
I previously found out how to program a limit switch that i can manually use. Now my question is how do i program a limit switch that will cause my motor to automatically stop spinning when it reaches a certain speed or position?
Unread 13-01-2012, 20:52
ssirovica's Avatar
ssirovica ssirovica is offline
Programming Captain
AKA: Sasha Sirovica
FRC #1458 (Red Ties)
ssirovica is an unknown quantity at this point
Re: Automatic limit switch
To stop a motor at a certain speed, that is a job for encoders. Encoders track the number of rotations of a shaft which you can use to compute the speed.
You could use a limit switch to stop a motor when the motor reaches a certain position, assuming that the motor turns some armature which physically turns the switch off.
The code for this in java would look like this:
DigitalInput limitSwitch = new DigitalInput(3); The constructor argument is the port its plugged into on the io board.
Then to get a Boolean value of weather it is closed or not use limitSwitch.get();
Good Luck!
Computers run on smoke. When you let the smoke out the computer stops working.
Unread 13-01-2012, 20:57
FRC #3556
im using labview
Unread 13-01-2012, 21:21
Originally Posted by adrianfarmer View Post
im using labview
There's a sub-forum under "Programming" specifically for LabVIEW.
If you post there, you increase the chances that your post will be read by LabVIEW programmers.
