Go to Post Instant Replay??? AAAAAAUUUUUGGGGGHHHHHH!!! - Bill Moore [more]
Thread Tools Rating: Thread Rating: 5 votes, 4.80 average. Display Modes
Unread 13-01-2012, 09:47
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Tracking Rectangles with Java/C++
Originally Posted by scottbot95 View Post
Would I be correct in assuming that in your example code, Camera is a class you made?
Yes, once we have our tracking code working completely and performing as we'd like, I'll likely post the full source code and an accompanying whitepaper.
Unread 13-01-2012, 09:57
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Originally Posted by davidthefat View Post
I am able to write the code in Java and port it into C++, but the C++ port will not be tested because I do not want to risk flashing the cRio too much.
Don't worry about it - it will take at least 10000 erase cycle to wear out any one block.
Unread 13-01-2012, 14:23
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
Originally Posted by vinnie View Post
My team is going to be putting a small Atom powered computer on our robot to do vision processing and other high-level functions. We are going to be using the javacv library to utilize OpenCV in Java. We experimented with vision processing on the cRIO last year, but we found that it was very slow and often lagged the rest of the robot functions. You can easily (I wrote a demo program in ~10 minutes) detect edges/contours with OpenCV and from there decide whether or not the contours make the rectangle you're looking for or not.
How exactly are you guys accomplishing that? Power connection, networking? Not sure how that would be done as we're also thinking of doing that.
Unread 13-01-2012, 17:18
JacobGH JacobGH is offline
FRC #1849
JacobGH is an unknown quantity at this point
I'm working on this problem in Java. Am I crazy or do they only make a method available for detcting ellipses and nothing else? Can we, at least, access the values for individual pixels? That way, if they give us nothing else, we could at-least write our own image processing algorithms.
Unread 13-01-2012, 20:33
I believe opencv and the axiscamera's JPEG is your best shot
Unread 15-01-2012, 15:54
scottbot95 scottbot95 is offline
FRC #1388 (Eagle Robotics)
scottbot95 is an unknown quantity at this point
basicxman, I tried the code you suggested and I found that we were finding a ridiculous amount of rectangles(around 42 million). Do you have any idea why this is happening? Also, is there any documentation for the imaqDetectRectangles function?
Unread 15-01-2012, 16:02
You probably want to filter by brightness (luminance) or color (probably in HSL or HSV space) before trying to detect rectangles.
Unread 15-01-2012, 16:11
I have a sheet of printer paper with the target(with correct proportions) printed on it except where the retro-reflective tape would be, we just printed green. I am then extracting the green plane and going from there.
Unread 15-01-2012, 17:37
Ross3098's Avatar
Ross3098 Ross3098 is offline
Programmer
AKA: Colin Ross
FRC #3098 (The Captains)
Ross3098 will become famous soon enoughRoss3098 will become famous soon enough
Our team is also trying to figure out how to track the rectangles. Ive been spending a few hours or so looking over nivision.h as well as a few white papers and i seem to have gotten this far:
m_ModifiedImage = m_HSLImage->ThresholdHSL(80,125,45,60,115,130);
ImaqImage = m_ModifiedImage->GetImaqImage();
The white paper about the vision targets talks about applying a convex hull operation to really help those rectangles pop out. The main problem I have at the moment is that I have no idea how to apply said operation in C++. Ive found the imaqConvexHull() operation but have no clue how to start it.
2012 FRC Championship: 4th pick, Quarterfinalist: Thanks 1507, 51!
2012 Michigan State Championship: 4th Seed, 3rd Alliance Captain, Semifinalist: Thanks 33 and 2137!
2012 Northville District: 3rd Pick, Quarterfinalist. Thanks 302, 4405!
2012 Waterford District: 2nd Pick, Finalist. Thanks 573, 3601!
2011 Waterford District: 8th seed, 1st pick, Semi Finalist. Thanks to 573 and 3770
2011 Ann Arbor District: 2nd seed, Finalist. Thanks to 548 and 247.
2011 Michigan State Championship: Semi Finalist. Thanks to 548 (Again) and 74.
2011 FIRST World Championship: 8th seed, Quarterfinalist. Thanks to 74(Again) and 846.
Unread 15-01-2012, 17:54
PriyankP's Avatar
PriyankP PriyankP is offline
FRC #0188 (Woburn Robotics)
PriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud of
This should help you get started! I'll be more helpful more once I see what the code I wrote does when I get it to run on a robot.
Champs Schedule Highlighter App [CD Thread]
#### XYZ Regional Finalists
Unread 15-01-2012, 18:06
Emily Horsman
Aye, if you generate C code from Vision Assistant it will call imaqThreshold too - something I forgot about in my original snippet.
Unread 15-01-2012, 18:14
rudun's Avatar
rudun rudun is offline
FRC #0496 (Royals)
rudun is an unknown quantity at this point
Would this be how to use the detectRectangles function in java. We looked at the ellipseDetect and I am thinking that hey do the same thing just based on different descriptors.
    private static final BlockingFunction imaqDetectRectanglesFn =
            NativeLibrary.getDefaultInstance().getBlockingFunction("imaqDetectRectangles");
    static { imaqDetectRectanglesFn.setTaskExecutor(NIVision.taskExecutor); }
    private static Pointer numberOfRectanglesDetected = new Pointer(4);
     public static RectangleMatch[] detectRectangles(MonoImage image, RectangleDescriptor rectangleDescriptor,
            CurveOptions curveOptions, ShapeDetectionOptions shapeDetectionOptions,
            RegionOfInterest roi) throws NIVisionException {
        int curveOptionsPointer = 0;
        if (curveOptions != null)
            curveOptionsPointer = curveOptions.getPointer().address().toUWord().toPrimitive();
        int shapeDetectionOptionsPointer = 0;
        if (shapeDetectionOptions != null)
            shapeDetectionOptionsPointer = shapeDetectionOptions.getPointer().address().toUWord().toPrimitive();
        int roiPointer = 0;
        if (roi != null)
            roiPointer = roi.getPointer().address().toUWord().toPrimitive();
        int returnedAddress =
                imaqDetectRectanglesFn.call6(
                image.image.address().toUWord().toPrimitive(),
                rectangleDescriptor.getPointer().address().toUWord().toPrimitive(),
                curveOptionsPointer, shapeDetectionOptionsPointer,
                roiPointer,
                numberOfRectanglesDetected.address().toUWord().toPrimitive());
        try {
            NIVision.assertCleanStatus(returnedAddress);
        } catch (NIVisionException ex) {
            if (!ex.getMessage().equals("No error."))
                throw ex;
        RectanglesMatch[] matches = RectanglesMatch.getMatchesFromMemory(returnedAddress, numberOfRectanglesDetected.getInt(0));
        NIVision.dispose(new Pointer(returnedAddress,0));
        return matches;
Unread 15-01-2012, 18:20
Ross3098's Avatar
Programmer
AKA: Colin Ross
Correct me if I am wrong but does this mean that the integer that the imaqConvexHull() operation returns to is the score? And also I am wondering if the destination image is actually modified within the operation.
Unread 15-01-2012, 21:29
Ross3098's Avatar
Programmer
AKA: Colin Ross
What is imaqConvexHull() returning to? I have it returning to an integer but what value does the integer have?
Unread 15-01-2012, 21:45
From the CVI documentation,
Return Value
Type
Description
int On success, this function returns a non-zero value. On failure, this function returns 0. To get extended error information, call imaqGetLastError().
Greg McKaskle
