Go to Post I get in enough trouble mentoring one team. If I did five teams I'd be less one wife. - Koko Ed [more]
Unread 13-01-2012, 08:55
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Does Your Team Use 4 CIMs on Your Drive?
Originally Posted by Dad1279 View Post
I'm sure that depends on the application, wheels, gearing, etc......JVN spreadsheet is your friend..... we will confirm with testing.
Back to OP, check the following chart (thanks to team 358): http://team358.org/files/mechanical/...nRefTables.jpg It clearly shows the advantage to 4 CIMs in a conventional traction drivetrain.
Precisely why I said YMMV.
I really like that spreadsheet, it is what I use quite frequently when picking gear ratios for drivetrains.
This just occurred to me: with 4 CIMs in a drivetrain you will run into two limiting factors in a pushing match. The drive train will be traction-limited, extra motors won't help here because you simply can't get their power/force to the ground. The drive train will be current-limited, i.e. you'll start popping breakers before you lose traction. The issue here is that with 4 CIMs you run the risk of popping the main breaker (120A) before you pop the individual (40A) breakers. Adding two more motors will not improve performance in this situation either because the main breaker will go before any of the individual motors will.
Extra drive motors might help a small amount with acceleration and other dynamic situations, but IMO 4 CIMs can accelerate a full-weight robot very well, even with high gearing.
Unread 13-01-2012, 09:08
Chris is me's Avatar
AKA: Pinecone
For what it's worth, the 120A breaker can sustain 160A for about a minute before tripping. The auto-reset breakers are much faster acting.
Unread 13-01-2012, 09:17
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Interesting. Do you have a source for that? I'm curious.
Odd that it's dubbed a "120A" breaker if it will allow significantly more current for such a long period of time.
Edit: NVM, found it in the breaker spec sheet here: http://team358.org/files/electrical/120aMainBreaker.pdf
Unread 13-01-2012, 13:23
GilaMonsterAlex's Avatar
GilaMonsterAlex GilaMonsterAlex is offline
Lead Team Mentor
FRC #3785 (Gila Monsters)
GilaMonsterAlex is an unknown quantity at this point
Definitely go with 4 CIMs. Like someone already said, we have so many other options that there's no reason not to use 4 CIMs.
Last year we used 4 CIMs, Toughbox(12.5:1), and 8" wheels. We played defense, and were super quick and tons of torque (very technical terms). We never popped a breaker, and we were at max weight.
Unread 13-01-2012, 14:05
Brinks3302 Brinks3302 is offline
FRC #3302
Brinks3302 is an unknown quantity at this point
If you use 4 CIMs, all with separate speed controllers, is it legal to split the PWM feeds so that the right side speed controllers are both receiving input from PWM 1 and the left from PWM 2 (or some variation on that)? Is the meaning of rule R61 to prevent this?
Thanks
Unread 13-01-2012, 15:49
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
If you want to know if you can use a Y-connector like the one in the picture below, the answer is yes. It should be in the KOP according to the checklist. It is listed as "Cable, Servo, Y-splitter."
I would say that this is the best practice for controling multiple motors/speed controllers that need to be run at the same speed because of the minimal failure points.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 13-01-2012, 16:02
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Our team uses 4 cims and a 2 speed dog shifter
Unread 13-01-2012, 16:57
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I suppose it depends on your definition of high gearing, but we have had robots in the 18-20 FPS range that accelerate sluggishly.
If you want to run a max weight robot at those kinds of speeds your acceleration will suffer with only 4 CIMs.
2001-2004: Team 100
2006-Present: Team 254
Unread 13-01-2012, 20:20
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
we have used mechanum every year except '09, requiring 4 cims... we used 4 cims in '09, 2 for shooter, geared up 1:2, 2 for drive w/ 12.75:1.
we will almost certainly use 4 this year
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 13-01-2012, 21:43
KennyLives's Avatar
KennyLives KennyLives is offline
Grand Vizier of Pneumadynes
AKA: Kenneth Prouty
FRC #2122 (Team Tators)
KennyLives is an unknown quantity at this point
Definitely use 4 CIMs.There is NO advantage to using 2 of them. If you need another high-torque motor, there are plenty of banebots motors to suit your purposes.
No leaks. Ever.
Unread 13-01-2012, 21:48
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Good point. A 2-spd transmission will really help getting to those high speeds I imagine.
