Go to Post The great thing about liking someone in your robotics team is that they've already seen you at your worst, and you cant shock them with ANYTHING anymore :D - SCROSSLEY-GCEC [more]
Unread 13-01-2012, 21:54
Mr.Trips Mr.Trips is offline
FRC #3179
Mr.Trips is an unknown quantity at this point
Stuck in evaluation mode!
Stuck in evaluation mode, we have tried several ways to make our project go to edit mode but have well...failed. When we try to build the program the error pops up and says you are still in evaluation mode and need to be in edit mode so please help
Unread 13-01-2012, 22:03
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Re: Stuck in evaluation mode!
You didn't mention the steps that you tried.
LabVIEW must be activated to use some features, this can be done via the "NI License Manager" and find the current version of LabVIEW. If it is green, then it is already activated, if not, then click on activate, and follow the prompts. I suspect that you may have not entered your serial number during installation. (Or it was mistyped.)
Mike B
