Go to Post Us, as adults, find ways to help the kids to make it happen. - aspiece [more]
Unread 13-01-2012, 22:31
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Drive Question
You have it right, most teams use 4 cims in the drive, two per side, installed in one transmission.
There are a lot of wheels, look at AndyMark's web page
http://www.andymark.com/Wheel-s/229.htm
also IFI (now VexPro)
http://www.vexrobotics.com/products/...on_vexpro=4536
also some teams make their own, or adapt other wheels to fit robots (both of which takes some effort).
Unread 13-01-2012, 23:36
eulerddx4
Posts: n/a
Re: Drive Question
Thanks for your input! When you say one transmission what exactly do you mean?
Should we put chain to all 6 wheels or should we just power 4? My mentor is saying that putting chain to all 6 is not necessary but I just don't know if he's right or not.
Unread 13-01-2012, 23:43
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Re: Drive Question
Always power all wheels. Unpowered wheels are wasted weight and offer an additional way to get the robot stuck on something. It also offers redunceny in the drive train so if you throw a chain you still have some mobility. The extra 2-3 lbs it takes to power all the wheels is worth it.
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: Drive Question
Chain to all 6. Better yet check out the Kitbot on Steroids by 1114
It gives full instructions on how to build a kick-butt drivetrain from mostly the KoP.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 14-01-2012, 01:13
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Re: Drive Question
While you technically don't have to power all the wheels, doing so will allow you more traction because all your weight would be on driven wheels. A couple years ago, we had the battery and a few other components over undriven wheels, so we lost several pushing matches. I'm not sure how to explain the physics behind this, but here goes. f=un (friction = coefficient of friction*normal force). The normal force at the drive wheels is basically the weight of your robot at that point. The more weight you have on your drive wheels the more traction you can get. Additionally, if you plan to go over the barrier, or possibly even the ramp, powering on the wheels will help prevent you from high centering (yes, there will be other factors, but everything helps).
Additionally, I think most teams use plaction wheels from Andymark for a tank drive.
