Go to Post it is easy. you will have to define "easy" in your own terms. - Mike Martus [more]
Unread 13-01-2012, 22:17
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
LabView 2011 Install Problems
Look I know this is a repost but I need a fix ASAP. Every time I try to install LabView from the drive included in the kit I get an error.
What I've done so far:
Turned off my firewall.
Completely uninstalled everything LabView using Revo Uninstaller.
Tried our flash drive.
Tried team 48's drive (has been 2 times to my knowledge).
Tried our drive.
Searched the error on LabViews site.
Searched the error here.
I haven't had access to another computer to install it on.
Here's the picture of the error along with the install progress.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 13-01-2012, 22:32
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Re: LabView 2011 Install Problems
The screenshot is better then your last post, but an answer has been posted for you. Double posting only causes confusion for people with the same error.
For reference: Previous post: http://www.chiefdelphi.com/forums/showthread.php?t=99957
Mike B
Unread 13-01-2012, 22:38
FRC #0379
Yeah I know. I tried to delete the first post but I cant do it. The old one is too cluttered with false stuff and clutter. I have gone through all of the posts made there and none of them come up with the answer or tell me something that wasn't in a previous post. I'm sorry if I sound impatient but my team is gonna kill me if I don't figure something out in the next 24 hours.
Unread 13-01-2012, 23:07
SuperS_5's Avatar
FRC #1219
Have you tried installing without your firewall, antivirus, and any other anti-malware software enabled? Temporarily turning them off, (even if that means disconnecting from the internet for self imposed security.) and then installing LabVIEW. The MS firewall and security essentials play nice with LabVIEW. So did AVG a few versions back. I have not tested anything else.
Mike B
Unread 14-01-2012, 00:06
FRC #0379
The only anti-virus I have installed is MSE and its definitely disabled
Unread 14-01-2012, 00:40
SuperS_5's Avatar
FRC #1219
Have you tried to copy the installer to your hard-drive and run it from there?
Mike B
Unread 14-01-2012, 00:57
bdbayes bdbayes is offline
Captain
FRC #2927 (Pi Rho Techs)
bdbayes is a jewel in the roughbdbayes is a jewel in the roughbdbayes is a jewel in the rough
I had a similar problem while installing Labview. It has to do with the configuration of your machine. The machine does not allow for Labview to install the C++ redistributable that it needs. To fix it, you need to do the following.
1. If you have a 64bit operating system, download and install both package 1 & 2. If you only have an 32bit operating system, download only package 1.
Package 1
Package 2
2. Run the installer again, it will still return this error, however, you want to instead continue the installation. It will repeat this message multiple times, so you will need to tell it to continue each time.
3. Labview should now work just fine. I have yet to have any problems with it. Autodesk will also return you a similar error, however it will not let you skip so easily. If you should try to install Autodesk on that computer, feel free to contact me for help.
Unread 14-01-2012, 10:15
FRC #0379
BD that's exactly what I needed, a different solution. I tried to install that and it came up with an almost identical error. I've been doing some searching on my own and its coming up with my lack of Visual Studio on my laptop. I don't know how that happened but I'll figure something out.
Unread 14-01-2012, 10:20
Captain
Even after having installed visual studio, I still had the same problem. You should only need the redistributable to fix it. It will always return an error while installing, as long as you continue the installation, the program seems to work fine.
Unread 14-01-2012, 14:25
FRC #0379
I'm so desperate right now that I'm just gonna reinstall windows 7 and see what happens.
Unread 14-01-2012, 16:07
Captain
Let us know how your Windows 7 reinstall goes.
Unread 15-01-2012, 13:12
Here's a Microsoft Knowledge Base article that might be relevant to your situation.
http://support.microsoft.com/kb/902330
Unread 15-01-2012, 13:18
Captain
Thanks for the info. Unfortunately, this did not fix it on my computer.
Unread 15-01-2012, 19:17
AquaMorph's Avatar
AquaMorph AquaMorph is offline
Alumnus of 2059
AKA: Christian Colglazier
FRC #2642 (Pitt Pirates)
AquaMorph is on a distinguished road
Have you uninstalled all things National Instruments on your computer? Not just LabVIEW.
Unread 17-01-2012, 14:15
FRC #0379
Okay so I reinstalled windows and I went to install LabView and it WORKED. But I have no Robotics Vi's and it doesn't give me the option to create a cRIO project or a Robot Project or anything. And I tried running the FRC Tools exe on the flash drive to no progress. Any ideas.
