Go to Post We can help make those dreams, maybe. ;) - Adare180 [more]
Unread 14-01-2012, 00:04
4057programmer 4057programmer is offline
FRC #4057
4057programmer is an unknown quantity at this point
vxWorks problems
I am having troubles getting the vxworks downloadable kernal module sample project working. As I try to get into it it displays the following error code:
The capability VxWorks 6.x Development is invalid because the underlying platform is not available. This leads to unexpected results in Wind River Workbench. Please check the installation
After that I try to select a sample file but there are none up there. I have the WPILib.a file in the vxworks folder, and I think I have all required updates. Any thoughts?
Thanks for your help!
Unread 14-01-2012, 09:35
Re: vxWorks problems
Did you by any chance install Workbench 3.3 from disc 2 without first installing Workbench 3.0 from Disc 1?
Unread 14-01-2012, 11:32
FRC #4057
No I installed them in the correct order. If nothing else I will try to re-install them again though.
