Go to Post My crotchety old person opinion is that it should be illegal to try to win the award. Do things because you like doing them or because it helps others. Don't do things to win awards. - Madison [more]
Unread 13-01-2012, 21:21
Lalaland1125 Lalaland1125 is offline
AKA: Ethan Steinberg
FRC #2429
Lalaland1125 is an unknown quantity at this point
Is TCP communication allowed in-game?
Our team is planning to process images on the Classmate. Our plan is to simply open a socket on the classmate on a high number port and simply push data back and forth using TCP. This obviously works right now in testing.
My question is: Can we do this during competition? Are teams allowed to communicate with their robot from a background task on the Classmate over TCP on a high number port?
(I know there will be speed issues due to network congestion etc, during the competition).
Unread 13-01-2012, 21:25
bdbayes bdbayes is offline
Captain
FRC #2927 (Pi Rho Techs)
bdbayes is a jewel in the roughbdbayes is a jewel in the roughbdbayes is a jewel in the rough
Re: Is TCP communication allowed in-game?
See the rule below.
[R53]
Connections to the cRIO Ethernet ports must be compliant with the following parameters:
The DAP-1522 wireless bridge is connected to the cRIO Ethernet port 1 (either directly or via a CAT5 Ethernet pigtail).
Ethernet-connected COTS devices or custom circuits may connect to any remaining Ethernet ports; however, these devices may not transmit or receive UDP packets using ports 1100-1200 except for ports 1130 and 1140.
Unread 13-01-2012, 21:30
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
We are also persuing this method. However, one must be VERY careful as to not cause excessive bandwidth/other bottleneck issues because the fms people will complain.
In previous years they had a screen that shows network data for each robot and a log so no funny business
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 13-01-2012, 21:39
FRC #2429
So, it seems like there are two main rules:
1. Do not use those port numbers in the range 1100-1200.
2. Try not to act like you are running a Denial of Service attack on the network.
Unread 13-01-2012, 21:45
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
you could use the camera direct to the classmate/laptop last year via a special labview .vi for the dashboard (I have a copy if anybody wants it to play with). Last I checked they still are using the 4 port AP's on the bot (only way to use them with the 4 slot crio), so if you connect the camera there, you can view the camera from the dash via the special VI.
I think that is legal... that looks to be the same rule as used in 2011.
edit- attached the .vi
Unread 13-01-2012, 22:23
This is included by default this year.
Unread 14-01-2012, 00:07
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
How are you getting the TCP comm link to work?
I'm currently unable to find the networking API from java..
Unread 14-01-2012, 00:10
ratdude747's Avatar
AKA: Larry Bolan
cool... since I am no longer actively involved with a team this year, I didn't know. Sorry about that.
Unread 14-01-2012, 10:24
FRC #2429
http://ideone.com/9dM5E
That's our code as of roughly now(I think the only change was that the robot does not support UTF, so we just switched that to ASCII or something).
javax.microedition.io is where the magic is.
If you want I can give you our server-side code, but it's just standard socket opening and accepting a connection(in C++ that is).
Unread 14-01-2012, 11:08
Why can't you just go with message = m_inputStream.readUTF(); instead of all that, which should do the same thing? and same for outputStream with writeUTF
Unread 15-01-2012, 14:22
pspeer's Avatar
pspeer pspeer is offline
Programming / Electronics
FRC #1730 (TeamDriven)
pspeer is an unknown quantity at this point
Has anyone been able to get TCP communication from the DriverStation to the cRIO using C++?
Does WPILIB support the use of TCP/UDP sockets?
Unread 19-01-2012, 16:10
MohammadAdib MohammadAdib is offline
Outside-of-the-box thinker
FRC #0948 (NRG948)
MohammadAdib is an unknown quantity at this point
In normal Java there are easy ways to implement a client server solution. From what i have seen/learned/experienced, it is always noteworthy that a client and server should talk with each other as little as possible while still maintaining communication. If your program requires sending a large amount of small data (such as coordinates) back and forth, then i suggest that you disable Nagle's algorithm, otherwise all of your small TCP packets will be made into one big packet and get sent, and that can mess things up quite a bit if you have some sort of command parser on the other side waiting to read the packets u send. Now that being said, in my opinion the ideal solution is to have the classmate running a server application listening on an open ServerSocket. A client will be on whatever you decide to send data to the classmate with which will try to connect to the classmate via some method of network communication. Then you can let the data flow. But if you are sending small amounts of data (< 1kb) then i recommend using a DatagramPacket (UDP). Regardless how you do it, Here is a useful site on making server and client solutions in Java: http://systembash.com/content/a-simp...nd-tcp-client/
If you have any technical questions about ANYTHING feel free to email me or something.
EDIT: I forgot to mention an extremely critical thing. Always make your servers threaded! That means for every client that connects to the ServerSocket on your server application, start a new designated thread for handling communication. If your server talks back, then also start another thread for sending info on the socket. Without threading, performance will TANK.
Unread 19-01-2012, 16:55
FRC #0948 (NRG948)
I just wrote and tested this very simple code for a threaded TCP server template using Java. The server is fully threaded and can read input from incoming clients. There is no limit to how many clients can connect. It uses a thread to search for new clients and once a client connects another thread is started for reading input from that client's socket.
Feel free to use the code as it is a template, but please do not remove the credit comment on the top
Download the file from below:
Unread 19-01-2012, 19:11
pavanetti's Avatar
pavanetti pavanetti is offline
FRC #1382
pavanetti is an unknown quantity at this point
I did so:
http://www.chiefdelphi.com/forums/sh...d.php?t=100558
(Post 5)
Unread 19-01-2012, 21:33
What do you guys think about a restful server so it will be easier to develop and test for?
I feel like a constant connection is not necessary. Also, how are you guys structuring rthe network? Server on laptop or server on crio. The formal seems simpler
