Go to Post Based on my experience coaching basketball and robotics, there is no doubt in my mind that if a sports coach receives $x then a robotics coach should, too. - dtengineering [more]
Unread 14-01-2012, 00:16
Re: classmate charger power requirement
Originally Posted by IceStorm View Post
For those of you with working classmates do you think this is the right adapter and tip? supply voltages look correct but i wasn't sure about the tip size or polarity.
I haven't found a definitive answer for the size of the power connection. I do know that Kensington tip "H" works correctly. The AT&T Wireless link I posted last year is out of date, but I believe http://www.amazon.com/Kensington-K38.../dp/B001WAK6J2 is the same thing at nearly the same amazingly low price.
Unread 22-01-2012, 17:12
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
I just ordered the one off amazon that was recommend in the last post. Will let you know our results. It should be here sometime next week.
Help! We lost our Classmate Charger Ed Law General Forum 6 03-03-2011 11:43
Power your Classmate PC with this cable sanddrag Electrical 15 22-03-2010 14:04
Drawings/CAD requirement? Numbers General Forum 6 09-02-2010 22:35
Passport Requirement News dtengineering General Forum 0 25-02-2007 21:33
SPI Requirement To Purchase archiver 2001 3 24-06-2002 00:33
