Go to Post P.S. I'm not boring! - Matt Krass [more]
Unread 14-01-2012, 00:57
bdbayes bdbayes is offline
Captain
FRC #2927 (Pi Rho Techs)
bdbayes is a jewel in the roughbdbayes is a jewel in the roughbdbayes is a jewel in the rough
Re: LabView 2011 Install Problems
I had a similar problem while installing Labview. It has to do with the configuration of your machine. The machine does not allow for Labview to install the C++ redistributable that it needs. To fix it, you need to do the following.
1. If you have a 64bit operating system, download and install both package 1 & 2. If you only have an 32bit operating system, download only package 1.
Package 1
Package 2
2. Run the installer again, it will still return this error, however, you want to instead continue the installation. It will repeat this message multiple times, so you will need to tell it to continue each time.
3. Labview should now work just fine. I have yet to have any problems with it. Autodesk will also return you a similar error, however it will not let you skip so easily. If you should try to install Autodesk on that computer, feel free to contact me for help.
Unread 14-01-2012, 10:15
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
BD that's exactly what I needed, a different solution. I tried to install that and it came up with an almost identical error. I've been doing some searching on my own and its coming up with my lack of Visual Studio on my laptop. I don't know how that happened but I'll figure something out.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
