Go to Post Here's my standard for-every-new-member-of-Chief-Delphi-Welcome: WELCOME TO CHIEF DELPHI!!!!!! :D - [more]
  #91   Spotlight this post!
Unread 14-01-2012, 08:35
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Strategies for Rebound Rumble
Originally Posted by rich2202 View Post
You can hoard on your bridge. BTW: You have to be up on the score to make hoarding work. Given the short time frame of the game, why bother developing hoarding abilities when you might as well use the time to get ahead even more?
Without advocating anything, there are two very straight-forward (but not necessarily easy) reasons:
- You can't win a head-to-head Teleop, but you beat them in Hybrid
- You know you can't win a head-to-head Teleop, and the best bet for your alliance is the Bridge. Even if it's not guaranteed, it could be your best shot if that's the way the alliances are skewed.
Essentially, If you can gain a considerable lead in Hybrid or get within your Bridge differential, but know you can't hold it once their Teleop scoring picks up, shutting down ball control could be very effective. Don't assume the only way to get ahead it to do something that hoarding inhibits.
  #92   Spotlight this post!
Unread 15-01-2012, 09:33
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
swwrobotics is an unknown quantity at this point
Is there a rule against using your kinect as a sensor on your robot?
  #93   Spotlight this post!
Unread 15-01-2012, 11:42
markbean markbean is offline
FRC #1923
markbean is an unknown quantity at this point
Originally Posted by Tetraman View Post
Make a robot with a ramp allowing another robot to drive on top of you, and you then solve the problem of how to get 3 robots on the bridge. Also, you can use it with your opponent's robot so you and your opponent can easily balance on the Coop bridge together as one entity rather than two.
Why build a ramp when there are already three perfectly good ramps on the field? Build a robot 24" tall (or compacts to that height) that can hold a field ramp in the up position so another robot can climb on top of you.
Some remaining problems to solve are::
  • How do you keep the robot on top of you from falling off when you try to get on the ramp? They would need to have a very low center of gravity as well.
  • How do you fit in gathering and shooting mechanisms in a robot that short?
  #94   Spotlight this post!
Unread 15-01-2012, 14:14
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
No, but there are a lot of implementation issues. Search for the kinect threads.
One clarification you may need is: Who supplies the Kinect for the Hybrid mode?
