Go to Post Good Luck all - this one will hurt your brain, but it's all in a good way. - meaubry [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 14-01-2012, 09:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: KOP Wheels and Bearings
It should not be an issue if the bearing sticks out of the wheel a little bit.
Unread 14-01-2012, 09:57
mama_tree's Avatar
mama_tree mama_tree is offline
FRC #3168 (WARRIORS)
mama_tree has a spectacular aura aboutmama_tree has a spectacular aura aboutmama_tree has a spectacular aura about
Yeah, we just noticed that the wheel sprockets have a much larger hole than last year's. Only thing is the axle spacers may need trimming.
2010- Virginia Regional Rookie All Star
2010- Newton Division Highest Seeded Rookie Team
Unread 14-01-2012, 10:07
MrForbes's Avatar
AKA: Jim
We didn't have to trim anything, it all went together just fine. One thing that did cause a slight problem was not seating the bearings all the way, if you don't, then they'll be crooked and the axle won't go thru easily. Easy to fix, just push harder on the wheel (when it's laying on the work bench) to force the bearings in as far as they can go.
