Go to Post FIRST: there is no second. - BandChick [more]
Unread 13-01-2012, 13:40
UriF UriF is offline
FRC #2213
UriF is an unknown quantity at this point
Communicating with cRIO over WiFi
Hey.
I've had an idea that involves using a Windows Program running on the Driver Station's laptop to get images from the Camera, do some image processing, and send some data back into the cRIO.
My question is, how do i communicate with the cRIO over WiFi and which ports do i send data to? how to get the images off of it? and, how do i receive data from within the cRIO? I haven't seen any functions for this purpose on the WPILib reference..
(I'm using C++ as the programming language).
Thanks in advance.
Unread 13-01-2012, 17:45
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Communicating with cRIO over WiFi
Originally Posted by UriF View Post
Hey.
Thanks in advance.
If you plug the camera into the router, you can bypass the cRIO and pull the images via HTTP. There are some other threads that go into detail about that.
Unread 13-01-2012, 18:59
FRC #2213
Alright, but the issue of sending data to the cRIO and using it still remains..
Unread 13-01-2012, 19:46
cgmv123's Avatar
AKA: Max Vrany
The theory is that the dashboard code would do the vision processing and send the code to the cRIO. Again, I defer to other threads on the vision tracking subject.
Unread 14-01-2012, 04:03
FRC #2213
Alright, assuming I use the dashboard for vision processing, how would i receive it within the cRIO code ? (C++) I haven't seen any function to do such a thing in the WPILib reference..
EDIT: I've found this class called SmartDashboard and this class called Dashboard.
It specifies some functions, which, if i understand correctly, are used to Get and Put data from and to the Dashboard.
Are there any examples for the usage of this Class? I think the info on the WPILib reference is insufficient..
Unread 14-01-2012, 09:37
cgmv123's Avatar
AKA: Max Vrany
Again, I'll defer to other threads on the vision tracking subject. I won't be the one doing it, so I don't know all the details.
Unread 14-01-2012, 09:56
The KinectGestures example has some commented out calls to the SmartDashboard.
Unread 14-01-2012, 10:34
kccowan kccowan is offline
AKA: Ken Cowan
FRC #1073
kccowan is an unknown quantity at this point
BTW, for competition, your laptop needs to be wired into a router, which communicates over WiFi to the robot. In the shop, you can take shortcuts and use WiFi directly to the robot's radio or tether directly to the robot's radio. The key is that you need to form a network link with the robot.
See the other threads for how to get camera images to the laptop. Once you process the image on the laptop, you'll need code in your dashboard to establish a socket connection to code in your robot that establishes a socket connection. Check out msdn.microsoft.com for samples on network programming.
Once you have your own connection, you can send commands from the dashboard to the robot. The commands can be anything you want.
KC
